Vanstyle rear spoiler kit.
Just in case anyone is wondering, this is what's included the Vanstyle rear spoiler kit. Also I've just downloaded Tapatalk and I'm trying it out with this post, so I might cock this post up.
- Mindak
Re: Vanstyle rear spoiler kit.
Looks similar to the genuine kit and probably half the price, good luck with fitting it I fitted mine last week!
It was £100 with VAT and postage, I'm getting the van colour coded next week so may as well let the experts fit it! Was it difficult to fit?Mindak wrote:Looks similar to the genuine kit and probably half the price, good luck with fitting it I fitted mine last week!
Whats the quality of it like? I'm getting my Caddy resprayed and wouldn't mind buying one, just don't want one of the shit kits.
Hey Gareth, I haven't seen one of the other kits but this one seems spot on. No "seams" or evidence of the moulding process and it feels solid. The fittings and threaded components look good quality too. I'll share some photos once it's on.Gareth wrote:Whats the quality of it like? I'm getting my Caddy resprayed and wouldn't mind buying one, just don't want one of the shit kits.
The gap is unavoidable unfortunately, you need to leave space between the two spoiler sections so the door clears when opening or closing.
The trick is to line the two sections up so the outside gaps are the same and the inside is minimal. Believe me, it's easier said than done.
- Mindak
I found drilling the holes inside the hardest part!
- Barbel330
I bonded mine on, took all of 5 mins to fit and you get plenty of wiggle room to position it exactly where you want it before it sets. I've positioned mine slightly lower (only a few mm) than most seem to because I didn't want the leading edge sticking up above the roof line, I wanted it to follow the roof line.
Instagram: @y_5cuf
- Mindak
I wish I bonded mine was such a ball ache! lol
Does the template in the kit not help??
- Barbel330
I personally didn't want to drill a load of holes in my rear doors, there's no need. Bonding is quicker and much easier to get the spoiler precisely lined up where you want it.
Instagram: @y_5cuf
- Mindak
It does but the inside holes need to be much bigger to get the nut on the back so a socket too, not a great angle to get a drill either I would bond it if I had to do it again!LSG wrote:Does the template in the kit not help??
What did you use to bond it? Sikaflex?
I fitted mine last week, got a friend to give me "polyutherane bond", he said its like tiger seal but takes a little longer to set unless you have a specific gun for applying it, i just smeared what I needed and left it on for 13 hours and seems fine.
Definetly good quality from vanstyle, I lost the manual and the rubber seals as when he painted it he must have misplaced them so I just used a spark plug feeler gauge set at 3mm in total and made it that all the way around and it seemed fine.
