Mk2kompressor wrote:Real nice work, I’ve got to take my headlining down due to a lovely dent in the top of the a pillar then either trim it or dye it black.
You might aswell if you have to take it off! I left mine in when I did it, might be better to trim it if your taking it completely out.
17shaggy88 wrote:I kno what you mean mark !
I live up beeches road, just off ware road just after the speed camera of your coming from ware to Hertford.
I know where that is, someone I know used to live up there years ago! Nice to have someone local, what's your caddy? I'll flash if I see you 🖒
Ahh cool man, yeah il do the same, the mrs was over my shoulder and has said that she has seen you about a few times ! (She said because of the Dakar sticker)
Mines a white 15plate highline, fairly standard at the moment with Audi wheels on and riding high
How do I add a photo on here? I can't work it out haha
17shaggy88 wrote:Ahh cool man, yeah il do the same, the mrs was over my shoulder and has said that she has seen you about a few times ! (She said because of the Dakar sticker)
Ahh cool I'll keep an eye out for you 🖒 if you need a hand with anything just let me know, pretty much found out the hard way with everything I've done so far . I use the tapatalk app, can upload straight from your gallery really easy.
D green wrote:Hi Mark2k haw did you dismantle your front bumper have bought one that needs paint had a quick look just not sure how it's done thanks
If you put it face down, you can unclip everything from the back. It's basically all push fit clips with a couple of screws each side for the lower part. You sort of have to pry the clips apart with a screwdriver while pulling from the other side it took me 10 mins tops. The lower grills just pop out. If you have any trouble let me know and I'll send you some more pics. Good luck 🖒
Mark2K wrote:So after 2 weeks of being Ill I finally managed to get around to finishing off the interior trim and head lining. Sprayed the last few bits and dyed the headlining black with material dye (needs one more coat once dried properly). Just need to get some touran door cards and centre console and the front is done. Time to start the build in the back
Looks awesome mate. I'm looking to do the same with mine. What primer and spray paint did you use - how close to the rest is it?
Cheers.
I used a paint for rigid plastic that required no primer. There is a pic of the can somewhere towards the beginning of the thread as can't remember what it's called now lol.
