***update***
Been busy once again...
Had my 2nd night away this time snowdonia way...
Cracking night..alot warmer..even had both front windows slighty open an was nice an cosy with all the blankets we had!
Got back gave the van a good clean and after applying auto finesse sealant last week van came up well!
Also finished off the rear window and side doors. Decided to stick the foam/foil insulation to rear window and then carpet over. And same with side doors.
Next job is to rear clip roof with stronger clips!
** Limbo's Maxi build! **
Re: ** Limbo's Maxi build! **
Insta : Limbo118118
- TonyC
Hi bud, quick question about you rear windows. Did you scrape a tint off the inside leaving an outer tint?
