Page 1 of 5
GolfChicks Red Van
Posted: Tue Mar 13, 2018 8:15 pm
by Golfchick
Having owned a Mk2, Mk3 and Mk4 golf I'm finally once again a VW owner having picked up my red van a week ago (I've only left the VAG club once and owned a Ford Galaxy for a year yuuuuck).
I held out for a van that wasn't white or BG blue and I wasn't after a Maxi either as most of the time it's either just me and my bike or me and my dog so I didn't need the extra space.
Got lots of plans for it but mostly standard stuff, a single bed that slides out so I can sleep it for a maximum of two nights. Already picked up a 9mm Saris Traps bike mount and will pick up a 15mm adapter next so all my bikes can be mounted.
I've already stripped out a naff bluetooth kit and the bulkhead and trimmed the bulkhead down. I've also replaced the interior bulbs so have LEDs, have an even brighter Festoon on its way to light up the load area a bit more though.
Re: GolfChicks Red Van
Posted: Tue Mar 13, 2018 9:47 pm
by Afield23
Welcome fellow biker! Looks like a nice van there
Sent from my SM-G928F using Tapatalk
Posted: Tue Mar 13, 2018 11:41 pm
by Paul9616
Well you don't see many of them in that colour?
Posted: Wed Mar 14, 2018 5:07 am
by geo.stronach
Welcome. Like the colour
Posted: Wed Mar 14, 2018 11:41 am
by Golfchick
Cut down the usual rubber matting choice this morning, leave it unstuck for now as I have plans to make a hatch/hinge on the right side where it covers over the unused side step so I can store the spare wheel tools and warning triangle.
Some recommendations of glue to use would be good to stick it down.
Posted: Wed Mar 14, 2018 2:01 pm
by Caddyluv
Just contact adhesive you can get for screwfix. Apparently you can stick a elephant to a tree, but whilst your there maybe you should sound deaden the floor under the ply to help with noise.
Posted: Wed Mar 14, 2018 5:10 pm
by Golfchick
Yeah I'm definitely going to sound deaden under the flooring, its easy to pull up so won't be a problem to stick down the rubber to then pull it up and sound deaden.
Posted: Thu Mar 15, 2018 8:32 pm
by L22JCJ
Looks smart in red against the black
Posted: Thu Mar 15, 2018 8:36 pm
by Cheney663
Nice van, even nicer bike!
Posted: Thu Mar 15, 2018 10:06 pm
by Golfchick
Taken off the gopping purple raceface grips tonight, bought em just to give em a whirl but because they're the thick version they were giving me awful hand ache. Picked a pair of soft narrow DMR Deathgrips to try out!
Posted: Sat Mar 17, 2018 4:54 pm
by Cheney663
I’ve been using Ergon Enduro grips, I suffer with arm pump and these grips have all but got rid of it.
Posted: Sat Mar 17, 2018 8:03 pm
by Golfchick
Had half nelsons on before and was totally fine but felt like giving the purple grips a go when the half nelsons were wearing out.
Posted: Sun Mar 18, 2018 11:26 am
by ElliotH
Welcome. Great colour. What do the bike mounts fix to?
Did you buy the van from RRK?
Posted: Sun Mar 18, 2018 2:23 pm
by Golfchick
The bike mounts are going to bolt to the wood flooring that’s down and Which itself is bolted down to the two centre lashing points. I wanted to fasten them today but the weather has scuppered any outdoor work
Yes I did buy it from RRK.
Posted: Tue Mar 20, 2018 10:05 pm
by Golfchick
So over the Easter weekend my best mate is going to help me build my box/bed as he works for magnet and is a whizz with wood. Came up with the following design which will sit over the drivers side wheel arch and extend upwards. I'm going to buy some foam and make two pieces which will be my mattress with a sleeping bag stored inside the box when not in use. The back section will have the VW stencilled in the carpet and will also open upwards like a small flap which will allow access into the box when standing at the back of the van. The hope or plan at least is that the washer/pump will be then under this access flap for ease of washing the bikes. I'll also have a panel on the box somewhere with charging ports etc as I have an auxiliary battery. My other plan is that height wise it will only just be above the wheel arch so that I can use the box like a seat.
Van box design by
Alison Clarke, on Flickr
Van box design by
Van box design by
Van box design by
Van box design by
Van box design by
Van box design by
Van box design by
