2006 Silver Caddy
- xaheadx
Re: 2006 Silver Caddy
No coding or errors. You can code the rear wiper out, but since it’s disconnected that’s the same thing?
I just cable tied all the loose wires up out the way during the process.
I think the rear lock mechanism needs to come out first to get the rear wiper motor out. I didn’t do this because my panel had been butchered before, but I’m sure this step is needed.
I’ll post photos when I’m home!
If you code out your rear wiper, you won't have the issue of the front screen wash running when you push the stalk forward.
I just removed the rear hose at the pump to do away with the chance of the back door getting wet from an accidental activation of the rear wash. I have also fitted the correct stalk for a car with no rear wiper.
- xaheadx
Thanks Doc - I asked this exact same question on the electrical bit, thanks for answering!
Did you swop the pump? Or just disconnect?
Does disconnecting the rear wiper motor also turn off the rear window heater?
- xaheadx
Photos of the rear wiper delete:
Two bolts, the connector for the hose, and the plug
Where the motor connected to the van with the two bolts just visible
Temporary solution
Another temporary solution (but look's quite good.. cistern blanking plug from tool station)
Temporary solution
- xaheadx
Not really an update but found a genuine VW lightning cable cheap.. curly!
- xaheadx
This lot arrived today from Germany! H&R lowering springs and shackles
Already had these OPS sensors to fit:
Booked in Wednesday to fit the lowering kit and the OPS sensors yay!!
- xaheadx
Didn't get around to fit the sensors, as I haven't decided on a bumper strategy yet.
Did lower it tho
Before:
Rear:
Front:
After:
Did lower it tho
Before:
Rear:
Front:
After:
- xaheadx
Wasn't happy with the rear wheel alignment, so fitted some RAD axle relocating plates using the 15mm setting, and chopped the bumpstop down one notch.
Before:
After:
Fitted RAD plates & cut down bumpstop:
Before:
After:
- xaheadx
Fitted a rear door interior door handle: 30 second job!
Just got to cut a slot in the rear door card!
- Caddyluv
Uuuummm, RAD plate picture looks like a different van
Will be following this
- The polisher
Hi have the same year van. As yourself wondering what are the bulkhead delete trims as i want to get rid of mine but it will leave the metal work exposed at the sides ,lovely looking van very clean for a 06 keep up the good work
Touran seats, Touran Console, Touran carpets, Touran Door cards, Spoiler, German Plates, RCD 330, carpeted and insulated, TDI Mats, Stance lowering Kit, VW Mk6 Steering wheel, T6 Steelies, Bargain Sunvisor, Bragan Roof Rails,Touran mirrors
Instagram:HG_Metal_Polishing_13
Facebook: HG Metal Polishing
www.hgmetalpolishing.com
Ireland
Ireland
- xaheadx
You can either cut down your old bulkhead and carpet line them, or get the trims from eBay. The parts codes are on the forum somewhere. I got mine from eBay. There are 4 parts (1 upper & lower each side).
- xaheadx
- The polisher
Cheers think ill have a go at triming the old bulk head out as i have to take it out ,when i put in the touran console again cheers
Ireland
Ireland
