JD's Caddy Build
JD2k
JD's Caddy Build
Post by JD2k » Wed Apr 11, 2018 9:12 pm
Hi Everyone,
So I've finally got round to starting a build thread.. I've been a member for awhile and bought my white 2012 Caddy 1.6 TDI around 8 months ago.
Thanks to inspiration and help from the Forum, these are the mods I've done so far:
Rear wiper delete
VW Front Badge Black gloss
Sound proofed/insulated/carpeted the rear
Checked rubber flooring
Bulkhead removed
Fitted a Saris Tracks bed bike rack
18" VW Talladega wheels
Aftermarket Undertray
Pioneer SPH-DA120 Head Unit
Pioneer TS-WX120A compact under seat Sub
Updated heater control knobs
VW Touran seat bases
VW MK7 Golf R Seats
VW Caddy Life Centre console
Team Heko wind deflectors
VW TDI engine cover - custom painted
Van-X Glove Box lid
VW Dash Storage compartment with lid
VW Under bonnet insulation
VW RCD510/310 USB Panel Input Switch
VW RCD510/310 AUX Panel Input Switch
VW MK5 Golf Gti Pedals + Aftermarket R Foot Rest Cover
Audi S3 8V Air Vents
115ah Leisure Battery via Durite VSR kit + 600W Durite Pure Sine Wave Inverter
PORSCHE 911 Oil and Coolant Caps
Rear Windows Tinted 5%
Pictures and a bit more detail to follow :D
18" Talladega|MK7 Golf R Seats|Life Armrest|Pioneer SPH-DA120+TS-WX120A
JD2k
Re: JD's Caddy Build
Post by JD2k » Wed Apr 11, 2018 9:29 pm
Few pictures of the van the day I bought it...
JD2k
Post by JD2k » Wed Apr 11, 2018 9:42 pm
Then onto the good stuff...
Firstly started off small (newbie)..
Rear De-wiper using a blanking plug from screwfix
Gloss black VW badges (still need to fit the rear one)
JD2k
Post by JD2k » Wed Apr 11, 2018 9:57 pm
Cleaned... sound proofed and insulated
Silent Coat 2mm.. 40 Sheets did the trick
B&Q Recycled Plastic Insulation
B&Q Foil backed Bubble wrap & foil tape to seal the insulation into the cavities
JD2k
JD's Caddy Build
Post by JD2k » Wed Apr 11, 2018 10:11 pm
Removed the Bulkhead, Carpeted the rear and sound proofed the bed..
8m Mega Stretch Campervan & Caravan Lining Carpet & High Temperature Adhesive
Tecsound 50AL Van Flooring Barrier 2M Sound Proofing Material Underlay
For the doors... 3 x VOLKSWAGEN VW logo Stencil Ply Line
Caddyluv
Post by Caddyluv » Wed Apr 11, 2018 10:14 pm
Well done.
JD2k
Post by JD2k » Wed Apr 11, 2018 10:22 pm
Caddyluv wrote:Well done. ImageImage
Thanks CaddyluvImage
JD2k
Post by JD2k » Wed Apr 11, 2018 10:33 pm
Pioneer SPH-DA120 fitted (reverse camera coming soon..)
Upgraded heater control knobs fitted alongside aluminium air vent rings
JD2k
Post by JD2k » Wed Apr 11, 2018 10:44 pm
Golf R MK7 heated seats ft. checker-plate rubber flooring covering the ply in the back of the van
Caddy Life Centre console from Sirius Automotive
Removed the caddy seat bases for Touran bases
Fitting the centre console, got there in the end!
Seats going in.. what a difference :D
As the seats are heated, next job will be to get the them wired up!
JD2k
Post by JD2k » Wed Apr 11, 2018 11:01 pm
Almost forgot to mention the wheels...18" VW Talladega
pictures aren’t great so I’ll hopefully get a few more after a clean at the weekend
Hoping to have the van lowered at some point in the next few months.. possibly the ST Suspension ST X Lowering Coilover Kit
Ricksy1121
Post by Ricksy1121 » Thu Apr 12, 2018 3:54 pm
Like the seats, Iv cheaped out and got a set of Leon fr seats for £100
JD2k
Post by JD2k » Fri Apr 13, 2018 9:35 am
Managed to get a good deal on eBay from a guy who was less than 10 minutes drive away so couldn't resist!
They came with the rear seats & door cards so hoping to get those sold on eBay soon
waterboyrob
Post by waterboyrob » Fri Apr 13, 2018 5:45 pm
The build is coming on really well inspired!
Sorry in advance for the question as I am sure you have been asked this, how did you get on with fitting the seats was it fairly easy?
JD2k
Post by JD2k » Sat Apr 14, 2018 9:11 pm
Thanks much appreciated!
Yes they were surprisingly easy to fit.
The Touran bases went straight in and after shuffling the seats around a bit to locate them on the bases, it was an easy job bolting the seats down. I only needed a spline hex bit on the end of my wrench for the bolts
JD2k
Post by JD2k » Sat Apr 14, 2018 9:16 pm
Made the most of some sunny weather and washed the car and van todayImage
Who is online
Users browsing this forum: No registered users and 1 guest
