JD's Caddy Build
JD2k
Re: JD's Caddy Build
Post by JD2k » Sat Nov 24, 2018 1:15 pm
davecamus wrote:How low have you gone with it? Looks like it sits well!
I asked the guy to drop it around 60mm but he said it’s as low as it’ll go before any rubbing on the wheel arches. I’ve been over all sorts, speed humps, pot holes etc and all good so far!
18" VW R Talladega|ST X Coilovers|MK7 Golf R Seats|Pioneer Audio
https://www.instagram.com/jdcaddy2k/?hl=en
JD2k
Post by JD2k » Sat Nov 24, 2018 1:18 pm
Better now it’s had a wash ImageImage
Finsv
Post by Finsv » Tue Nov 27, 2018 9:40 pm
JD2k wrote:
Thu Oct 04, 2018 11:28 am
Little start up screen update for the head unit
Hello, what vent have you installed? Were they easy to install or did you have to play around with them ?
JD2k
Post by JD2k » Wed Nov 28, 2018 9:08 am
They're Audi S3 8V air vents, although they were pretty easy to fit, they're not a straight swap. The little plastic tabs on the inside edge of the hole in the dash needed a bit of filing down in order to get a good fit when inserting the S3 vents. Mine do rotate when opening and closing the vent but I have them permanently open so I'm not too bothered.
I found some details on Horace's Caddy build thread https://www.caddy2k.com/forum/viewtopic ... ts#p261695
I followed this guide to remove the standard air vents, it's easier once you've done the first one.
https://www.caddy2k.com/forum/viewtopic ... ilit=vents
Finsv
Post by Finsv » Wed Nov 28, 2018 9:21 pm
Okay ! Thanks for the help!
