JD's Caddy Build
Liam
Re: JD's Caddy Build
Post by Liam » Tue Jun 26, 2018 11:00 pm
making great progress there JD
http://www.tdr.ie
JD2k
Post by JD2k » Wed Jun 27, 2018 9:15 am
Whitey wrote:
Tue Jun 26, 2018 2:10 pm
Hopefully brooneyes solution will work. I found that CarPlay would drop out if using either usb extensions or cheap usb leads from the Headinit. I ended up buying a belkin usb lead which was only a couple of quid more than a cheapy. No problems since :)
Swapped out the long cheap iPhone cable I was using for an apple one and that's sorted it! Thanks guys
18" Talladega|MK7 Golf R Seats|Life Armrest|Pioneer SPH-DA120+TS-WX120A
JD2k
Post by JD2k » Wed Jun 27, 2018 9:22 am
Thanks Liam, getting closer to finishing things off on the inside. Going to try tackle painting the light grey trim and headliner next!
Caddyluv
Post by Caddyluv » Wed Jun 27, 2018 9:57 am
Never be finished there will always be another project.
JD2k
Post by JD2k » Wed Jun 27, 2018 10:33 am
Very true! it's a never ending process but an enjoyable one ( and expensive) :)
JD2k
Post by JD2k » Sat Jul 07, 2018 2:42 pm
Camping prep underway! New bed arrived today.. few little tweaks and it should fit like a gloveImage Need to sort out a split relay system for a leisure battery next Image
lewi_grf
Post by lewi_grf » Sat Jul 07, 2018 2:51 pm
Nice van, love the carpeted out back
JD2k
JD's Caddy Build
Post by JD2k » Fri Jul 13, 2018 9:42 pm
Fitted some MK5 Gti pedals today... a lot of messing around trying to get the accelerator pedal in but they’re in! (Excuse the dirty mat)
Oddy8911
Post by Oddy8911 » Sat Jul 14, 2018 9:38 am
Seats are looking great
JD2k
Post by JD2k » Fri Jul 27, 2018 6:58 pm
Another job ticked off the listImage
Audi S3 8V air vents fitted... not totally happy with the fitment but they’re in for now
JD2k
Post by JD2k » Fri Jul 27, 2018 8:04 pm
Tomorrow’s job... connect up a 115ah leisure battery with a split charge relay kit.. then fit a 600W inverter Image
caddychris2002
Post by caddychris2002 » Fri Jul 27, 2018 9:20 pm
JD2k wrote:Tomorrow’s job... connect up a 115ah leisure battery with a split charge relay kit.. then fit a 600W inverter Image
Where did you get the kit from pal
JD2k
JD's Caddy Build
Post by JD2k » Fri Jul 27, 2018 9:33 pm
Hi mate, got the kit from Simply Split Charge.. they’ve got loads of different kits on their online store.
I went for this one after seeing it posted on the forum. It comes with everything you need, even a drill bit and screws to fix the fuse box. The instructions are really detailed and easy to followImage
http://www.simplysplitcharge.co.uk/stor ... duct_id=75
The polisher
Post by The polisher » Sun Jul 29, 2018 11:16 pm
JD2k wrote:
Mon Jun 25, 2018 9:48 pm
After a long wait these finally arrived from eBay.. Need to figure out how to connect the aux port as it’s got an input for a RCD310 cable.. The USB port also seems to disconnect my apple car play connection after a minute or so but there’s still power.. So a little tweaking to do but at least they look better than blanksImage
w
Don't know if this will help but I found that if I used an after market cable on my CarPlay USB it would cut out after a few mins then I was told that the CarPlay like if you use the original iPhone cable to plug in. ,I got a original cable and all works well now , just in case
Touran seats,touran Console,Touran carpets,Touran Door cards,Spoiler, German Plates,RCD 330,carpeted and insulated ,TDI Mats,
Instagram:HG_Metal_Polishing_13
Facebook: HG Metal Polishing
Ireland :shock:
JD2k
Post by JD2k » Mon Jul 30, 2018 12:32 am
Thanks, yeah I swapped out the USB cable I was using for the apple one and that sorted it
Who is online
Users browsing this forum: No registered users and 2 guests
