Older pics now from when it was new and bright, but has been a great van
Sent from my SM-T805Y using Tapatalk
Our work Caddy
- Liam
Re: Our work Caddy
G’day welcome to caddy2k
Build thread here
Build thread here
- Ddraeg
Re: Our work Caddy
Welcome to the forum!
I was travelling recently and stayed for a while in Gympie!
Re: Our work Caddy
Finally get back in to the work vehicle after it sitting around for ages getting little use, so it's starting to get pimped out.
Replaced the head unit with an android sat nav one and have put down some sound deadening which has made a difference already and will be putting in some ply lining with carpet
Re: Our work Caddy
Going to add some draws in, using what I had in my 4wd and was going to finish off the rest with a false floor so there will be a completely flat floor over the wheel arches, but then picked up a single draw to be opened through the side door and then fill in the gaps to finish the floor
Re: Our work Caddy
Got the Golf GTI seats installed and electric lumber wired in, but unfortunately the drivers lumbar is broken.
Re: Our work Caddy
Slowly coming along
Re: Our work Caddy
Back draws finally finished, now to attack the front and then to finish off with the walls.
