Mtb/surf/camp van build
nodeward
Post by nodeward » Sun Aug 05, 2018 10:19 pm
Thought I would start a build thread as I’m starting to make some progress with the van. Picked it up a couple weeks ago and it’s pretty much a builders van . Image
In an effort to make it look a bit less White vanish, (on a budget at the moment with a house move looming) got a couple decals. Image
Quite like em but not 100% so might get rid eventually
Also managed to rip out the ply, put down some sound proofing and cover some of the original panels in a bit of carpet I got of Facebook for a tenner.
I’m pretty please with how it looks, will be carpeting the whole lot eventually and Still got to make a couple of panels for the tops of the sliding doors
mtbrider0
Re: Mtb/surf/camp van build
Post by mtbrider0 » Tue Aug 07, 2018 11:31 pm
Good work mate! Looks tidy :D
nodeward
Post by nodeward » Sun Sep 02, 2018 9:44 pm
Started building a unit in the back to store stuff. The bed will go right up to the wheel arch so trying to make the most of the space.
Started to do a bit of insulation at the same time, hopefully get s chance to finish it off next weekend
Cr51say
Post by Cr51say » Tue Sep 04, 2018 8:13 am
The unit is looking like a nice tidy start.
tonymoo
Post by tonymoo » Tue Sep 04, 2018 8:51 am
Looking good so far.. Great alternative racking to the usual..
quick question.. How are the carpeted panels mounted? Pics would be good. 😁
Tony
nodeward
Post by nodeward » Tue Sep 04, 2018 6:29 pm
Cheers,I think it should turn ok.
If you look at the first pic I have put some pieces of ply up under the edges of the panel lip. Secured it with some no more nails to stop it shaking lose and screwed panels to that, had held up pretty well so far
nodeward
Post by nodeward » Fri Oct 12, 2018 9:49 pm
Got my prototype shelves built, think they look pretty great. I will eventually add some doors them and either cover in something or remake the panels out of vaneered mdf ImageImage
Sent from my SM-J530F using Tapatalk
aerobic247
Post by aerobic247 » Sat Oct 13, 2018 2:42 pm
nice work so far. check out my build http://caddy2k.com/forum/viewtopic.php?f=12&t=24530
my Mountain Biking Camper build viewtopic.php?f=12&t=24530
nodeward
Post by nodeward » Sat Oct 13, 2018 6:20 pm
Finished wiring up my s-line SEATS, decided to go the standalone route and just put some switches in the centre console. Also fitted some eBay special reversing sensors.
nodeward
Post by nodeward » Sat Oct 13, 2018 6:24 pm
aerobic247 wrote:nice work so far. check out my build http://caddy2k.com/forum/viewtopic.php?f=12&t=24530
Already had a good look through you thread Mate, looks great and gave me loads of ideas. Gonna get a similar bed into mine once we have moved house
nodeward
Post by nodeward » Fri Nov 23, 2018 7:44 pm
Added some window in the bulkhead and a cargo net to stop stuff rolling around in the back ImageImage
nodeward
Post by nodeward » Sat Nov 24, 2018 5:28 pm
Wired up some lights in the back, only cheap ones but they are as bright as the sun ! Image
Mark-Tam
Post by Mark-Tam » Sun Dec 09, 2018 11:58 am
nodeward wrote:Got my prototype shelves built, think they look pretty great. I will eventually add some doors them and either cover in something or remake the panels out of vaneered mdf ImageImage
Look pretty sweet Image
Lister79
Post by Lister79 » Sun Dec 09, 2018 7:11 pm
Did you just use an aftermarket kit with the original heat pads for your heated seats or have you fit the full aftermarket kit?
2014 Toffee Brown 1.6TDi
MeisterR coilovers, Bilstein B6 rear shocks and shackle kit, Whiteline 24mm roll bar, Brembo 18Z calipers, EM Tuning headlights, plus loads more and a dog cage.
