2014 Blue Caddy - MTB / Camper
mintydrummerman
Re: 2014 Blue Caddy - MTB / Camper
Post by mintydrummerman » Mon Nov 05, 2018 5:41 pm
Hi MrRowlie
What did you do with your floor? Did you lay anything under the ply?
MrRowlie wrote:Image
Removed all the Ply and panels. Headliner is out. Bulkhead is out, and ready to mod to use as side trims.
Removed the old bumper protector, which was a right pain! Managed to get it off with a bit of heat, and then spent hours removing all the adhesive off the bumper!
Cheers Tweedy! Nice thread you’ve got yourself!
Sent from my H8216 using Tapatalk
"Racing is life, anything before or after is just waiting"
MrRowlie
Post by MrRowlie » Mon Nov 05, 2018 6:11 pm
There’s insulation underneath the ply, same stuff as you can see pictured on the walls.
The insulation is stuck down, then 12mm ply just sits on top (not fixed) and the laminate is just sitting on top of the ply.
I have fixed the bed down to both the ply and laminate, but nothing is fixed into the metal floor
SnoodyMcFlude
Post by SnoodyMcFlude » Tue Nov 06, 2018 6:01 pm
Nice, started doing something similar myself but not nearly as tidy and as soon as I got it usable it stalled :lol: Also it started getting closer to ski season and I realised I had better things to spend my money on.
Watching this thread with interest for some ideas :)
manx_rob
Post by manx_rob » Tue Nov 06, 2018 6:15 pm
Looking awesome mate, how did you wire in those led lights in the rear? I’m wanting to do something similar.
MrRowlie
Post by MrRowlie » Tue Nov 06, 2018 8:06 pm
manx_rob wrote:Looking awesome mate, how did you wire in those led lights in the rear? I’m wanting to do something similar.
I used the original interior light wiring. Used a 3 way rocker switch (I think that’s what it’s called) wired as Permanent - off - Switched (to replace the switch on the original interior lights)
I’ve also used 3 switches so I can independently switch each row of lights.
Completely over complicated things Image
manx_rob
Post by manx_rob » Tue Nov 06, 2018 8:07 pm
MrRowlie wrote: I used the original interior light wiring. Used a 3 way rocker switch (I think that’s what it’s called) wired as Permanent - off - Switched (to replace the switch on the original interior lights)
Yeah..... sounds it!! ImageImage
MrRowlie
Post by MrRowlie » Tue Nov 06, 2018 8:10 pm
Happy with how the bed has turned out so far, need to sort out a mattress next, and get some curtains up.
Giddy
Post by Giddy » Tue Nov 06, 2018 8:18 pm
Very nice! I'm always amazed what people can do with few planks of wood, mainly because I don't like doing any woodwork myself :)
My Caddy 4 build thread viewtopic.php?f=13&t=37368
Jason1
Post by Jason1 » Tue Nov 06, 2018 8:45 pm
Very nice
MrBlueSky
Post by MrBlueSky » Wed Nov 07, 2018 2:57 pm
Great job, what else are you planning on doing in the future?
MrRowlie
Post by MrRowlie » Thu Nov 08, 2018 2:55 pm
Next thing I’m going attempt to do is add a folding arm on the side of the bed which will act as a bike rack (secured by the 15mm axle)
Initially thinking of using a simple piece of 2” x 2”. However I’m going towards using something like extruded aluminium profile, which I could have the bike mounts able to slide side to side.
Something like this with channels.
JD2k
Post by JD2k » Thu Nov 08, 2018 3:14 pm
Nice work on the bed! I've got an off the shelf bike rack for a front axle mount similar to the AL extrusion you've mentioned which is a good idea.
If you had a couple of extruded channels running parallel you can have the bike axle mount fixed diagonally as well to stop the handle bars taking up space above the bed
18" VW R Talladega|ST X Coilovers|MK7 Golf R Seats|Pioneer Audio
https://www.instagram.com/jdcaddy2k/?hl=en
MrRowlie
Post by MrRowlie » Thu Nov 08, 2018 8:05 pm
JD2k wrote:Nice work on the bed! I've got an off the shelf bike rack for a front axle mount similar to the AL extrusion you've mentioned which is a good idea.
That rack gives a lovely clean install! Looks awesome. You are definitely onto something with the diagonal mountings, would make it a lot easier fitting multiple bikes in as well!
More to think about now Image
MrRowlie
Post by MrRowlie » Sat Jan 26, 2019 2:56 pm
Decided to put a little table off the rear door, couple of folding shelf brackets and a chopping board!
Strength test Image
Gary.8
Post by Gary.8 » Sat Jan 26, 2019 3:44 pm
Looking good.. did get round to fitting the 2020 aluminium profile bar?
I've got the bar and fork mounts but yet to fit it.Image
