Caddy 4 wheel drive build
Barbel330
Re: Caddy rs3 build
Post by Barbel330 » Sun Oct 28, 2018 6:38 pm
Some mk4 Caddys come with them from factory now. My mates 2016 has them.
Instagram: stuartcourt12
Caddyluv
Re: Caddy rs3 build
Post by Caddyluv » Sun Oct 28, 2018 7:27 pm
Yeah it’s a full inner plastic wheel arch replacement. They have moulded it to it.
james400
Re: Caddy rs3 build
Post by james400 » Sun Oct 28, 2018 7:38 pm
Will see how they turn out first
Barbel330
Re: Caddy rs3 build
Post by Barbel330 » Sun Oct 28, 2018 7:39 pm
Did you get a price? I need new rear arch liners.
Caddyluv
Re: Caddy rs3 build
Post by Caddyluv » Sun Oct 28, 2018 7:46 pm
No mate. Soz.
james400
Re: Caddy rs3 build
Post by james400 » Thu Nov 01, 2018 7:49 pm
Had the front bumper number plate smoothed just the rest of the bumper now to prep and paint ImageImageImageImageImage
james400
Re: Caddy rs3 build
Post by james400 » Sun Nov 11, 2018 3:55 pm
A few bits done 2day got some Touran door trims off a follow forum member and some s5 sill trims just need to get them prepped ready to be fitted. I've had for some time now some footwell lights genuine ones from a mk7 golf I've made some brackets and fitted them in still need to wire them up battery was a bit flat so lights don't look very bright also fitted some rear mud flaps ?? If that's what you call them lol also been rebuilding my new front brakes I've been sandblasting and painting them up will update the photos when I take some next week.ImageImageImageImageImageImageImageImageImage
james400
Re: Caddy rs3 build
Post by james400 » Sun Nov 25, 2018 6:00 pm
So my cecm unit come the other day and I went to fit it and code a few bits in but unfortunately some one has tryed to update the vcds at work and haven't done it correctly so it's not working so wasn't able to do anything on that side but I did wire in and pin in the footwell lights did a bit more of prepping ready for next weekend when the new chassis rails get put in on the rear ready for the new rear end and I've started on the front wheel arch trims off the all road caddy
james400
Re: Caddy rs3 build
Post by james400 » Sun Dec 02, 2018 7:15 pm
So some more done 2day so all the brackets have been removed from the rear end and the new chassis legs have been trimmed and being put into place 2moz will be trimed up so they fit better and will check double check and check again on all the measurements then rear axle will be temporarily bolted up for me to check it on the lasers if all comes back ok and we can get on with welding it in and bracing it early start tomorrow tho to get it done 'll upload more photos tomorrow. Also my mk2 golf coil overs come the other day so will be able to mark and cut out wheel arches ready for the new turrets ImageImageImage
james400
Re: Caddy 4 wheel drive build
Post by james400 » Mon Dec 03, 2018 7:45 pm
So if anyone asks me is it a easy mod to do then NO never again lol all the new chassis legs are spot welded on I've learnt a lot and still learning as I go but the axle is in and aligned a few bits still to do be For I can start welding it all up not much room but the top banana arm but I do have a plan regarding that and also still need to mark up and cut out the Archers for the suspension turrets but slowly getting there.ImageImageImageImage
Liam
Post by Liam » Mon Dec 03, 2018 8:17 pm
loving this - updates cant come quick enough
Remapped by Joe Power at TDR.ie
Passat Cc leather interior
18” Vancouver Reps
Eibach pro lowering kit
the list goes on 😝
http://www.tdr.ie
james400
Post by james400 » Mon Dec 03, 2018 8:19 pm
Thanks mate I do try and update as much as I can
