Caddy 4 wheel drive build
james400
Re: Caddy 4 wheel drive build
Post by james400 » Fri Feb 22, 2019 6:48 pm
So go a lot done 2day slowly getting there so the rear axle is up marked up where the coil overs are going and got the fuel take up still a lot to do but we are getting thereImageImageImageImageImageImageImageImageImage
Sean1066
Post by Sean1066 » Fri Feb 22, 2019 7:36 pm
It's coming together now James.
Can't wait until you finish this one
My build thread
james400
Post by james400 » Fri Feb 22, 2019 7:56 pm
Neither can I lol when all the cutting and welding is done I've got drop it all to seam seal it and paint it and then strip the rear subframe down to get it all painted and rebuilt with all my new parts just gota wait on my turret tops to be done was hoping to have them yesterday but they didn't get time to do them so can't do much more till they are done
brooneye
Post by brooneye » Fri Feb 22, 2019 8:00 pm
There’s some serious graft gone into James, no doubt it’ll be impressive and worth the wait
Giddy
Post by Giddy » Fri Feb 22, 2019 8:26 pm
This is an impressive project and some really good skills too!
Caddy 4, Highline, 1.4 TSI
Build thread https://www.caddy2k.com/forum/viewtopic ... 13&t=37368
james400
Post by james400 » Fri Feb 22, 2019 8:52 pm
Thanks guys I'm learning a lot as I go with this and bout the caddy's you never stop learning lol
Lister79
Post by Lister79 » Sat Feb 23, 2019 6:00 am
Looking good mate.
2014 Toffee Brown 1.6TDi
james400
Post by james400 » Sun Mar 03, 2019 1:45 pm
Just a quick updates just got back from London picking up a Tiguan fuel tank for the caddy I no I have fitted the golf 4motion tank but I wasn't happy with it so I've been doing a bit of research and it help with having one in at work but measuring up the Tiguan fuel tank and the measurements of the space on the caddy it should fit lovely so I off down the unit now to see How it fits will post photos and updates later 2night
james400
Post by james400 » Sun Mar 03, 2019 6:41 pm
Ok well the rear tank is the new one and the font one is the golf as you can see it smaller I've put it up and it is loads better much happyer with it still I've gota do a bit of cutting and welding as there is a cross member in the way what I'll do is cut it out order a new one from TPS and weld it in in a different place so that's the plan ImageI hope lolImage
james400
Post by james400 » Sun Mar 10, 2019 7:18 pm
So started fitting the fuel tank and getting that sitting correctly be for I finish off the welding and start seam sealing. so the mounts are spotted on and technically bolted in just put the axle stand under to hold it until I finish welding and putting the straps on. fuel tank sits nice now had to adjust the floor a bit as on the back of the tank it has a breather and the lugs it sits on also had to do it because I wasn't happy with how low it sat.ive gota get some fuel pipes made up what I'll do at work so no Biggie next is to sort out suspension turret tops and fuel filler neck once that's done then it's a little bit of tidying up a bit of welding then on to seam sealing ImageImageImageImageImageImageImage
MOR90
Post by MOR90 » Sun Mar 10, 2019 7:38 pm
Very interesting build that i will most certainly continue to follow.
Keep up the hard graft lad :D
james400
Post by james400 » Sun Mar 10, 2019 7:39 pm
MOR90 wrote:Very interesting build that i will most certainly continue to follow.
Thanks Image
MOR90
Post by MOR90 » Sun Mar 10, 2019 7:41 pm
Your welcome man 8)
Pepsi
Post by Pepsi » Mon Mar 11, 2019 9:27 am
Making good progress. Hope it all come together nicely.
james400
Post by james400 » Thu Mar 14, 2019 8:37 pm
So been doing a bit after work this week and now the tank is done as far as mounting anyway so dropping the tank now and can start seem welding the brakets and finishing put in the New Cross members.ImageImage
