Caddy 4 wheel drive build
Sean1066
Re: Caddy 4 wheel drive build
Post by Sean1066 » Tue Mar 19, 2019 12:11 pm
Sean1066 wrote:
Tue Feb 19, 2019 9:56 pm
Hi James
Where did you get your brake back plates from I can't seem to find 345mm ones for the front of mine?
What are the part numbers as TPS down in Devon will only serve you if you have the part number😡
My build thread
james400
Post by james400 » Tue Mar 19, 2019 7:30 pm
Sean1066 wrote: What are the part numbers as TPS down in Devon will only serve you if you have the part numberImage
The backing plates are for a rs3 not a caddy mate
Sean1066
Post by Sean1066 » Tue Mar 19, 2019 7:32 pm
I need ones for R32 brake calipers 345mm
I thought they were 345mm
My build thread
james400
Post by james400 » Tue Mar 19, 2019 7:49 pm
No mate the front ones are 370mm and the rear are 310mm that's what I have on now
Barbel330
Post by Barbel330 » Tue Mar 19, 2019 9:35 pm
You don't need to change stone guards with R32 brakes. Standard caddy stone guards are fine. I still use standard caddy ones now with my Brembo calipers and 350mm discs.
Instagram: @y_5cuf
Grifnut
Post by Grifnut » Wed Mar 20, 2019 4:07 pm
This is going to be a beast, top job 👍
james400
Post by james400 » Wed Mar 20, 2019 8:29 pm
Thanks mate its coming along slowly
james400
Post by james400 » Fri Mar 22, 2019 10:01 pm
Test fitted the wheels 2day ImageImage
Celticrsmith
Post by Celticrsmith » Fri Mar 22, 2019 10:06 pm
That’s lovely!!
james400
Post by james400 » Thu Apr 11, 2019 8:26 pm
Just a update so all the work under the van is now done so the big rebuild begins now new rear arms come 2moz so the weekend the coilovers can go on and start setting it up ImageImageImageImageImage
Barbel330
Post by Barbel330 » Thu Apr 11, 2019 8:50 pm
Getting there mate. Looks really good. :)
Instagram: @y_5cuf
caddychris2002
Post by caddychris2002 » Thu Apr 11, 2019 8:52 pm
This is amazing what door cards are those mate. Stunning work
james400
Post by james400 » Thu Apr 11, 2019 8:59 pm
It's getting there can't wait to start building it back up with all the new bits the door cards are Touran door cards but I've reupholstered them with the gtd fabric then fitted the lights in them
Sean1066
Post by Sean1066 » Thu Apr 11, 2019 9:01 pm
This is really coming together top job buddy.
My build thread
Lister79
Post by Lister79 » Fri Apr 12, 2019 8:41 am
Awesome mate.
2014 Toffee Brown 1.6TDi
