My CADDY Maxi Life 2010
chabi87
Post by chabi87 » Fri Nov 02, 2018 11:26 am
BEFORE....
NOW...
Hello everyone!
In this topic i want to boast about my
white Caddy 2.0 TDI 140HP from 2010 which, over time, changes visually and not only .... Image
The modifications I made were changing the backlight of the speedometer and the air conditioning control panel
pecik91
Re: My CADDY Maxi Life 2010
Post by pecik91 » Fri Nov 02, 2018 11:28 am
Hi and siema!
Jakie plany?
chabi87
Post by chabi87 » Fri Nov 02, 2018 11:43 am
Hi and siema!
At the moment, caddy is in the process of modifying the front. / W chwili obecnej caddy jest w trakcie procesu modyfikacji przodu.ImageImageImageImage
Wysłane z mojego PRA-LX1 przy użyciu Tapatalka
pecik91
Post by pecik91 » Fri Nov 02, 2018 12:19 pm
Miałbym prośbę. Masz 2.0tdi bmm? Mógłbyś mi podać numery pokrywy silnika? I wszystkie uchwyty do tego. Z góry dzięki :)
chabi87
Post by chabi87 » Fri Nov 02, 2018 2:31 pm
pecik91 wrote:Miałbym prośbę. Masz 2.0tdi bmm? Mógłbyś mi podać numery pokrywy silnika? I wszystkie uchwyty do tego. Z góry dzięki :)
Na chwilę obecną niestety nie, bo stoi na warsztacie, a poza tym to chodzi Ci o osłonę plastikową na silniku czy o pokrywę komory silnika - maskę?
pecik91
Post by pecik91 » Sat Nov 03, 2018 8:43 am
O tą plastikową i wszystkie uchwyty co są :)
chabi87
Post by chabi87 » Sat Nov 10, 2018 7:20 am
Finish :) ImageImage
pecik91
Post by pecik91 » Sat Nov 10, 2018 9:36 am
Good Job! How much does it cost in Poland? Front SWAP like Tours with painting and all work?
chabi87
Post by chabi87 » Fri Nov 16, 2018 8:08 am
pecik91 wrote:Good Job! How much does it cost in Poland? Front SWAP like Tours with painting and all work?
Thanks!
I did not count the costs yet - maybe at the weekend I can do it.
I will inform You :)
chabi87
Post by chabi87 » Fri Nov 16, 2018 8:10 am
More pictures... ImageImageImageImage
pecik91
Post by pecik91 » Fri Nov 16, 2018 9:46 am
Great work!
Liam
Post by Liam » Fri Nov 16, 2018 10:35 am
very nice looks great
Remapped by Joe Power at TDR.ie
Passat Cc leather interior
18” Vancouver Reps
Eibach pro lowering kit
the list goes on 😝
http://www.tdr.ie
