My CADDY Maxi Life 2010
Posted: Fri Nov 02, 2018 11:26 am
by chabi87
Re: My CADDY Maxi Life 2010
Posted: Fri Nov 02, 2018 11:28 am
by pecik91
Hi and siema!
Jakie plany?
Posted: Fri Nov 02, 2018 11:43 am
by chabi87
Hi and siema!
At the moment, caddy is in the process of modifying the front. / W chwili obecnej caddy jest w trakcie procesu modyfikacji przodu.
Wysłane z mojego PRA-LX1 przy użyciu Tapatalka
Posted: Fri Nov 02, 2018 12:19 pm
by pecik91
Miałbym prośbę. Masz 2.0tdi bmm? Mógłbyś mi podać numery pokrywy silnika? I wszystkie uchwyty do tego. Z góry dzięki
Posted: Fri Nov 02, 2018 2:31 pm
by chabi87
pecik91 wrote:Miałbym prośbę. Masz 2.0tdi bmm? Mógłbyś mi podać numery pokrywy silnika? I wszystkie uchwyty do tego. Z góry dzięki
Na chwilę obecną niestety nie, bo stoi na warsztacie, a poza tym to chodzi Ci o osłonę plastikową na silniku czy o pokrywę komory silnika - maskę?
Posted: Sat Nov 03, 2018 8:43 am
by pecik91
O tą plastikową i wszystkie uchwyty co są
Posted: Sat Nov 10, 2018 7:20 am
by chabi87
Finish
Posted: Sat Nov 10, 2018 9:36 am
by pecik91
Good Job! How much does it cost in Poland? Front SWAP like Tours with painting and all work?
Posted: Fri Nov 16, 2018 8:08 am
by chabi87
pecik91 wrote:Good Job! How much does it cost in Poland? Front SWAP like Tours with painting and all work?
Thanks!
I did not count the costs yet - maybe at the weekend I can do it.
I will inform You
Posted: Fri Nov 16, 2018 8:10 am
by chabi87
Posted: Fri Nov 16, 2018 9:46 am
by pecik91
Great work!
Posted: Fri Nov 16, 2018 10:35 am
by Liam
very nice looks great
Posted: Wed Jun 26, 2019 12:22 am
by chabi87
