SDI TO TDI HELP NEEDED
DUNNY101
Post by DUNNY101 »
new member to the caddy scene I have an amazing sdi caddy and love it to bits ive read a couple of threads about the engine swaps into sdi models but seem abit dated so just seeing if I can get some fresh info on the task at hand :) MORE PONIES IN THE SDI
any help is muchly appreciated
the task
sdi engine conversion what ,where, who ,how much how easy or a step by step would be lovely
shanky887614
Re: SDI TO TDI HELP NEEDED
Post by shanky887614 »
it all depends on your power goals.
if you google fitting an older engine into a bls that will explain the hardware side.
then you want to buy a bjb/bkc radpack off ebay for convinience
that will get you an intercooler,radiator and fanshroud all bolted together that will just bolt onto yours.
then you need the intercooler pipes/hardpipe kit
then it depends on what turbo you want to run
Sent from my ASUS_X00ID using Tapatalk
