My BG Caddy maxi build
Sean1066
Re: My BG Caddy maxi build
Post by Sean1066 » Sun Aug 04, 2019 3:39 pm
Been doing a bit today got my slip ring module ready to go in to take my Mk7
MFSW Image
Burnt my finger on the soldering iron Image
My build thread
Svenycaddylife
Post by Svenycaddylife » Mon Aug 05, 2019 3:25 pm
Got my vents in Image
Sent from my ANE-LX1 using Tapatalk
Sean1066
Post by Sean1066 » Mon Aug 05, 2019 6:25 pm
Very nice buddy.
The A3 vents look really nice on a caddy
My build thread
Svenycaddylife
Post by Svenycaddylife » Mon Aug 05, 2019 6:38 pm
Just needs some thicker foam between the vent and ducting to make a snug fit
Beardyginge
Post by Beardyginge » Mon Aug 05, 2019 7:11 pm
What else have you done to get them to fit properly? I’ve seen a couple of pics where other people have fitted them but they don’t always look quite right.
Svenycaddylife
Post by Svenycaddylife » Mon Aug 05, 2019 7:31 pm
The bottom of the dash needed small bit of plastic cut out that was it they are easy to get back out again
Timson
Post by Timson » Tue Aug 06, 2019 7:30 am
Nice work! I love this build, gives me a lot of inspiration for my own maxi.
Dan4da
Post by Dan4da » Tue Aug 06, 2019 11:14 am
Awesome thread, some really good inspiration for all us fellow BG van owners, keep us updated dude
Svenycaddylife
Post by Svenycaddylife » Tue Aug 06, 2019 6:05 pm
Beardyginge wrote: What else have you done to get them to fit properly? I’ve seen a couple of pics where other people have fitted them but they don’t always look quite right.
This is how much I cut out to give a snug fit the first one I cut a little to much but it still stays in the hole ok ImageImage
Sean1066
Post by Sean1066 » Tue Aug 06, 2019 7:00 pm
@Dan4da thank you for your nice comments
I always try and keep this build update.
@timson thank you for giving me the inspiration to keep on building. Hopefully you will start a build to inspire others.👍
My build thread
Sean1066
Post by Sean1066 » Tue Aug 06, 2019 7:08 pm
Well after a lot of headaches I have finally got my spacewalker module all wired up. Fitted in my caddy and got my Mk7 golf MFSW fitted and working.Image
Now I think that looks a lot better
My build thread
Svenycaddylife
Post by Svenycaddylife » Tue Aug 06, 2019 7:12 pm
Looks epic
Timson
Post by Timson » Thu Aug 08, 2019 8:48 am
That steering wheel looks amazing! I would like cruise control too. Is it possible to change the steering wheel like you did and code in the cruise control to work? So instead of a cruise control stalk I mean. I would then choose a MFSW over a stalk kind for convenience and the fact that you can also control the radio, etc.
Sean1066
Post by Sean1066 » Thu Aug 08, 2019 8:59 am
@timson
You will have to get a spacewalker module to do that.
Then you will have to do some soldering like I did
My build thread
Timson
Post by Timson » Thu Aug 08, 2019 9:13 am
Are there no MFSW's that do not require soldering in order for the cruise control to work? Like MFSW's from other caddy's?
