My BG Caddy maxi build
Sean1066
Re: My BG Caddy maxi build
Post by Sean1066 » Thu Aug 08, 2019 9:21 am
Not 100% sure
My build thread
claudiu2s
Post by claudiu2s » Thu Aug 08, 2019 2:11 pm
Timson wrote:
Thu Aug 08, 2019 9:13 am
Are there no MFSW's that do not require soldering in order for the cruise control to work? Like MFSW's from other caddy's?
if your van is 65 plate or above then u can use a Scirocco/Polo steering wheel with cruise and highline slip ring. If the van is pre 65 plate then u will need that special module Sean installed.
I have genuine VCDS, VagCAN Pro, SMOK and ODIS with online server access for any of your programming needs in Hemel Hempstead/Watford area.
vcds.diagnostic@gmail.com
https://www.facebook.com/pg/VCDSDiagnos ... e_internal
http://vcds-diagnostic.simplesite.com/
Timson
Post by Timson » Thu Aug 08, 2019 9:03 pm
I'm not familiar with the plate system as I am from the Netherlands. A quick google search shows me that a 65 plate was registered in september 2015. Does this mean that the fabrication year of the van must be 2015 or up? My caddy is produced in 2011.
Sorry for hijacking your build thread Sean!
Sean1066
Post by Sean1066 » Thu Aug 08, 2019 9:08 pm
@ Timson 65 = the year the caddy was registered
So 65 is the year September 2015 to March 2016
My build thread
Timson
Post by Timson » Thu Aug 08, 2019 9:16 pm
So that's the year of production of the vehicle? That means I would have to resort to the same way you made your MFSW work? Seeing as my caddy has the same production year as yours.
Nubnubb0r
Post by Nubnubb0r » Fri Aug 09, 2019 10:20 am
Where do you get these spacewalker modules from then? Also cracking looking van, was wondering if yiu used the same bumpers or got Touran ones sprayed as I would like mine doing just do not know which is easier?
Sean1066
Post by Sean1066 » Fri Aug 09, 2019 10:29 am
You can get the spacewalker module from this website
http://forum.xhorse.pl/viewtopic.php?f= ... 0bae4a373f
I got my bumper from gtikris on instagram.
It’s made from a caddy bumper and a Mk7.5 Golf R bumper.
My build thread
Nubnubb0r
Post by Nubnubb0r » Fri Aug 09, 2019 11:08 am
Ahh sweet. Were they the right colour then? That took me to a coding site. Take it its a standard module that you change using these tips?
Sean1066
Post by Sean1066 » Fri Aug 09, 2019 1:14 pm
They come like this
Image.
For the module just click home and look for the MFSW
My build thread
