Mk IV Caddy 2.0 102 Startline BMT
Post by the swan fiend » Wed Mar 27, 2019 9:06 pm
Cheers for the advice mate.
What’s the cab headliner like to remove?
ViralEye
Re: Mk IV Caddy 2.0 102 Startline BMT
Post by ViralEye » Wed Mar 27, 2019 9:12 pm
It was a pain lots of hidden screws but all made all made sense
Post by the swan fiend » Wed Mar 27, 2019 10:50 pm
Just what I wanted to hear
ViralEye
Post by ViralEye » Thu Mar 28, 2019 6:11 am
the swan fiend wrote:Just what I wanted to hear Image
Haha it's just again something to take your time with. Happy to help if you ever get stuck
Post by the swan fiend » Thu Mar 28, 2019 6:32 am
Thanks mate
ViralEye
Post by ViralEye » Fri Apr 19, 2019 5:05 pm
About time I gave the whip its first proper clean so made the most of this amazing weather with a wash, clay, polish and a wax!Image
ViralEye
Post by ViralEye » Wed Apr 24, 2019 9:45 pm
So that's the Caddy back in the garage and sounds a bit more serious
The previous belt squeak got sorted but it developed another belt squeak and with it being the cam belt tensioner I thought I'd best get it in sooner or later. Also thought whilst it's going in a might as well get the passenger handle sorted
Called them up today for an update - new handle has been ordered.... Let's hope not from Germany! And they mentioned they are having to strip back some parts to try and find out what's casing this belt squeak... Doesn't fill me with confidence
ViralEye
Post by ViralEye » Thu Apr 25, 2019 10:06 pm
Yay it's fixed again! Then it broke again... But then I fixed it!!!!
Turns out the sticking handle was a bracket inside the door that had broken
Belt squeak was cam belt tensioner(again), and also the idler
Fixed??? Yes, but then on the way home the EML came on but the van drove normal. Get the obdeleven on and it's something about exhaust pressure sensor... Turns out VW just didn't plug it back in
Fingers crossed all fixed now!
ViralEye
Post by ViralEye » Sat May 04, 2019 8:13 pm
So, decided comfort would still be on the agenda before I go into body work and wheels etc, so treated myself to some absolutely mint heated S3 seats in full leather
Now I just need to figure out how to fit them without touran bases
bob86
Post by bob86 » Sun May 05, 2019 4:56 am
Why don't you want to use touran bases?
ViralEye
Post by ViralEye » Sun May 05, 2019 8:21 am
Why waste money on bases that may not be required? I've seen a lot of people say they found it too low without them, but also a lot saying they was absolutely fine without them
james400
Post by james400 » Sun May 05, 2019 8:22 am
I fitted mine with out the basis you just redill the 2 front seat holes but you do sit low in them with out them.
ViralEye
Post by ViralEye » Sun May 05, 2019 8:27 am
I suppose it depends how tall your body is to whether you'll find them low or not?
Quick question though - I know when your removing a steering wheel you need to disconnect the battery and leave for 10 minutes before unplugging the air bag.... Is it the same for seats?
james400
Post by james400 » Sun May 05, 2019 8:49 am
To be honest you only need to leave it if your doing wiring on the airbag system if your only removing and refitting you dont need to leave it as long as your not poking the wires has your caddy got airbags in the seats??
ViralEye
Post by ViralEye » Sun May 05, 2019 8:55 am
Yeah got air bags in the current and new seats. I know I need a new loom so won't be able to connect then back up at the moment but I'll worry about that in a few weeks time
