Black maxi (life wanta be) camper
Re: Black maxi (life wanta be) camper
Post by Stedlocks » Tue May 28, 2019 7:49 am
Looking very nice!
I've just fitted a Stance + kit and it has those little tabs at the end of the top plate....I was wondering what they were for :D I'll have to look into getting a couple of those bars, although it seems plenty stiff at the minute?
I love a black caddy ;)
Castoutdoors
Post by Castoutdoors » Tue May 28, 2019 10:59 pm
Cheers @Stedlocks I not seen them on other kits that why when with them. I like the idea to try stop the twist I guess ?
Castoutdoors
Post by Castoutdoors » Tue May 28, 2019 11:05 pm
Got the other love of my life out this weekend at the local trail beautiful dusty out Image.
Also found time to change the rear badge over to a gloss black one Image
Just can’t decide what to do with the lettering? Remove it or plastidip in Matt black ?!
Post by Stedlocks » Wed May 29, 2019 12:07 am
Get it gone!😂
Gary.8
Post by Gary.8 » Wed May 29, 2019 9:14 am
Looking good I bet it's fun getting that Santa Cruz on and off the roof rack....
sent from Huawei using Tapatalk
benc
Post by benc » Wed May 29, 2019 5:11 pm
Nice bus pal I like how you made the bed. How did you fix itdown?
Castoutdoors
Post by Castoutdoors » Wed May 29, 2019 9:40 pm
Gary.8 it not too bad. The bike pretty light as well for full enduro bike. I have to use the passenger door step up where I am bit of short ass but it a lot easier now the van sitting closer to the floor
Castoutdoors
Post by Castoutdoors » Wed May 29, 2019 9:49 pm
Benc at the moment the bed is not fixed down which isn’t ideal I know. I can get cam straps thou the holes in unistruct worse case. However I have plans for the mk3 bed with possible using bits off rear bench on maxi life and the oem anchor points. Just need to check how all locks in and how going to sort the sliding draw for the fridge
Castoutdoors
Post by Castoutdoors » Fri May 31, 2019 10:59 am
At last the rear door cards for the sliding doors have turned up from VW better get fitting them tonight Image
Castoutdoors
Post by Castoutdoors » Fri May 31, 2019 8:10 pm
Doors cards fitted nice easy all just clip into the factory holes and smarten up the rest of the van now looks more finished
Before I started I carpet the hard board panels and added some shapes to match the trims in the front but was never happy with it
This the top trims
And finished doors
Cy Russ
Post by Cy Russ » Fri May 31, 2019 9:08 pm
Loving the black facelift maxi, have you fitted any heat insulation if so what did you use? Going to follow this thread.
Castoutdoors
Post by Castoutdoors » Fri May 31, 2019 11:19 pm
@Cy Ross thanks !
When I insulated it I use the recycled plastic stuff from B&Q I wanted to use the sheep’s wool insulation from company called black mountain but couldn’t get it quick enough at the time. These both are lot healthy to use that a glass fibre product. I have stuffed it in the ceiling side doors and the void in the back and tailgate I never bothered with vapour barrier as there far to many holes and voids to make it work properly. And did the same in my last van and that last 8 years !
Castoutdoors
Post by Castoutdoors » Sat Jun 01, 2019 10:52 am
Few better pictures of the life dash
And shows off my pedal kit off as well.
Thinking I need to get the brushed door handles and windows switches to finish it all off
Castoutdoors
Post by Castoutdoors » Sat Jun 01, 2019 10:55 am
@Stedlocks back end cleaned up! Have to agree it looks a lot better nowImage
Castoutdoors
Post by Castoutdoors » Sat Jun 01, 2019 10:57 am
And found time this morning to get the footwell light wired in. I have go them so come on when the light come on rather than the interior lights
With get better pictures when it dark
