Caddy 2007 lowering
Johnnydv8
Caddy 2007 lowering
Post by Johnnydv8 » Thu Aug 01, 2019 1:48 pm
Ok so I have this ex British Gas van πŸ‘πŸ½ I’m doing the TDI conversion on it but also need to know the best way around lowering the rear end ?drop plates ect ?
Any advise from any one would be amazing ! FANKS ALL!!
Andyspuregrey
Re: Caddy 2007 lowering
Post by Andyspuregrey » Thu Aug 01, 2019 2:49 pm
axle flip kit, I got mine from darkside developments, there is a low or super low kit. Other brands area available also.
Johnnydv8
Post by Johnnydv8 » Thu Aug 01, 2019 2:53 pm
Nice one thanks for that will have a look πŸ‘πŸ½πŸ‘πŸ½
Giddy
Post by Giddy » Thu Aug 01, 2019 5:56 pm
What's going up the front then? If you're buying full kit, it comes with everything you need for the front and rear.
Caddy 4, Highline, 1.4 TSI
Build thread https://www.caddy2k.com/forum/viewtopic ... 13&t=37368
craig.head
Post by craig.head » Thu Aug 08, 2019 9:13 am
did you get a kit and if so which one did you use and are there any instructions for fitting available?
Johnnydv8
Post by Johnnydv8 » Fri Aug 09, 2019 9:34 am
I haven’t bought a kit yet but I will run coil overs on the front πŸ‘πŸ½
Svenycaddylife
Post by Svenycaddylife » Fri Aug 09, 2019 11:18 pm
Has any used the weld on plates for the rear ?
Sent from my ANE-LX1 using Tapatalk
Johnnydv8
Post by Johnnydv8 » Sat Aug 10, 2019 6:50 pm
I will need to sort something so may give these a try let you if I do πŸ‘πŸ½
