AZV TDI into a SDI
Johnnydv8
AZV TDI into a SDI
Post by Johnnydv8 » Sat Aug 10, 2019 7:06 pm
Ok so I have done away with the idea of the 130 pd and have bought a touran with the AZV 2.0 TDI for the caddy conversion and wanted to know if I should use the drive shafts and hubs from the touran or just run the original caddy brakes and shafts ? Only thing is I think the brakes on the touran are bigger ? Thoughts ??
jack.oneill14
Re: AZV TDI into a SDI
Post by jack.oneill14 » Wed Aug 14, 2019 11:17 pm
It depends are ur shafts 28 or 30 spline? Id run 30 on the tdi. The brakes should also be changed as the sdi used a smaller size disc
Johnnydv8
Post by Johnnydv8 » Thu Aug 15, 2019 9:49 pm
Ok so I can swap everything from the touran into the caddy including the hubs 👍🏽 It will all go in ok including the struts as I take it these are 55 mm ?
jack.oneill14
Post by jack.oneill14 » Fri Aug 16, 2019 8:52 am
Yeah as long as they are 55mm they should
