AZV TDI into a SDI
Posted: Sat Aug 10, 2019 7:06 pm
by Johnnydv8
Ok so I have done away with the idea of the 130 pd and have bought a touran with the AZV 2.0 TDI for the caddy conversion and wanted to know if I should use the drive shafts and hubs from the touran or just run the original caddy brakes and shafts ? Only thing is I think the brakes on the touran are bigger ? Thoughts ??
Re: AZV TDI into a SDI
Posted: Wed Aug 14, 2019 11:17 pm
by jack.oneill14
It depends are ur shafts 28 or 30 spline? Id run 30 on the tdi. The brakes should also be changed as the sdi used a smaller size disc
Posted: Thu Aug 15, 2019 9:49 pm
by Johnnydv8
Ok so I can swap everything from the touran into the caddy including the hubs
It will all go in ok including the struts as I take it these are 55 mm ?
Posted: Fri Aug 16, 2019 8:52 am
by jack.oneill14
Yeah as long as they are 55mm they should
Posted: Wed Aug 21, 2019 2:21 pm
by deanj469
Is this a pretty straight forward swap?
Posted: Wed Aug 21, 2019 4:00 pm
by jack.oneill14
As long as u have a full van it should be
Posted: Wed Sep 04, 2019 11:39 am
by Johnnydv8
Yep all done sorted all good thanks swapped over the lot from the touran
Including a 16” spare lol because of the bigger brakes
