Edition 30 lowered on Rotiforms
Re: Edition 30 lowered on Rotiforms
Yep that looks very cool , cant really see from the picture but has it got a black roof as standard ?
Yeah, black roof and rails come as standard on the Edition 30's.
I have the same knocking noise on mine now its lowered on Vmaxx extreme - please someone tell me what it is!?!?!?
- torque777
We're rear dampers tightened on the ground? Are the rear damper shafts tight on to the fixing bush as these can be loose
was this ever found out what the noise was??
- dan@biali
It could be the rear mounting bushings. Happened on my KWs and I've heard of similar issues with vmaxx too. Only solution was to replace the bushings. In my case KW exchanged my V1s for V2s which have better quality bushing and the noise went away.
