Led lights in the trunk door
Hi guys. I don't know how to correctly call it in English but I would like to ask you about adding the led lights in the trunk door (as seen on a picture).
I asked VW dealer. Showed them this picture from VW site and ... nothing in ETKA and what more ... they've asked VW and the answer was ... Where did they find it (the picture)? No comment;) Maybe you know something more (connection, part numbers) or someone already done it.
Re: Led lights in the trunk door
I don't know the answer but I like it, keep us posted!
Just get a couple of boot lights out of any old mk4 Golf etc cut the holes and link into your existing boot light. Want to trim my boot panel so might do it myself while I'm on.
- tommyzooom
I assume they are led footwell light units,(Mk 7 golf perhaps) and yes, connected to existing boot light
Do I need to follow the harness from boot door to boot light on (LHD) left side? or just somewhere in the door after removing boot panel? If I need to follow the harnes from boot door to boot light I'll wait for a reversing camera to mount to make it 2 in 1;)
You will need to run cables into the tailgate from the light so like you say, may as well kill two birds with one stone.MartyPL wrote:Do I need to follow the harness from boot door to boot light on (LHD) left side? or just somewhere in the door after removing boot panel? If I need to follow the harnes from boot door to boot light I'll wait for a reversing camera to mount to make it 2 in 1;)
So this mod will wait (together with reversing camera) untill spring and longer, warmer days;) Lights are already ordered (footwell leds from Golf7,Touareg - part number 5G0947409) . Thanks guys!
Here's the strip led I fitted in my tailgate ( the camera makes it look on the piss )
Operated by the switch in the rear wiper motor cover.
I ran a single cable through the wiring gland ( pain of a job )
2014 Caddy Maxi Life 2.0dsg BMT
Mk7 style multifunction steering wheels that will work available. viewtopic.php?f=20&t=20691
well .... So there is one part number 4B0 947 415 A (in my ETKA this PN "belongs" to PHAETON or TRANSPORTER) ... but what about KDP ETV 00013? If I'm gonna change it I would like to have LED light source;)
Thanks a lot!
Thanks a lot!
Finally fitted. Pictures viewtopic.php?f=1&t=9927&p=197367#p197367
