broken new van already!!!!
so went a bit wild with the power washer and washed the engine not too much to be honest. so anyway it cut out and its very very hard to start and in limp mode and esp light and engine light is on. throwing code P0652. an ideas anybody??
Re: broken new van already!!!!
http://wiki.ross-tech.com/wiki/index.ph ... 652/001618
This might be of use.
- dan@biali
No have washed plenty of engines before with no issue till nowdan@biali wrote:Did you protect any of the electrics before power washing?
- paul4314
did u solve this best thing i recommend is pull all the plugs of and wd40 them and reconnect i have done many engine washes never had this issue so can either say u accidently got to close to a connection without noticeing or some one has lost/removed the water proof seals from a plug somewhere is that the only code u are getting up as this is alll i got from ross tech site
are u using vcds to get codes
Have tried this checked all connections they all seem fine no signs of water in any of them at all. . Have ecu out now send it off to have that checked.
Try checking the wiring loom between the engine and the chassis leg, common problem!!
- Adam87
Mine did same thing when washed, wiring loom that crosses over the gearbox had worn through!
