RNS315 sat nav with built in bluetooth istallation.
stan-the-man
Re: RNS315 sat nav with built in bluetooth istallation.
Post by stan-the-man » Sun Apr 26, 2015 1:08 pm
The bastid must have switched the casings or something.
Gibbo
Post by Gibbo » Sun Apr 26, 2015 1:49 pm
Or it's a sticker !! Or like I said a Chinese version or something else is wrong with it !!
NornIron
Post by NornIron » Sun Apr 26, 2015 4:41 pm
Here's a useful post on briskoda.net, basically clarifying whether your 315 has BT, DAB or a combination of both:
http://www.briskoda.net/forums/topic/28 ... bluetooth/
Seems as though mine is a non BT unit, mis-sold on eBay :(
Ich habe kein Geld!
dan@biali
Post by dan@biali » Thu Apr 30, 2015 1:13 am
My RNS315 did the same thing when you pressed the phone button it just said mute but after it was coded in vagcom and had a microphone connected the BT then worked.
Gibbo
Post by Gibbo » Thu Apr 30, 2015 9:27 am
dan@biali wrote:My RNS315 did the same thing when you pressed the phone button it just said mute but after it was coded in vagcom and had a microphone connected the BT then worked.
thats a good point and makes sense,
Norniron I have vagcom, where are you ? Do you have a mic ? Or I can email instructions to you
Post by Doc » Thu Apr 30, 2015 9:43 am
Gibbo, just a suggestion here but why not post up your instructions for everyone to see? I don't see the point it instructing an individual via email when the entire forum can benefit and save the question coming up again. I personally refrain from giving detailed instruction via email or PM for just this reason. Better to serve the community than one individual.
2013 1.6TDI, Edition 30 18" BBS Peschara, Caddy4 rear lights, 2016 Polo GTI (mk7 style) steering wheel, TRC front splitter, Relentless Tuning front coilovers, Audi A6 S-Line front seats, mk6 GTI Front & rear Brakes, 3D Colour Premium dash cluster, Caddy life arm rest, Motexion bulkhead, 2016 MIB head unit
Gibbo
Post by Gibbo » Thu Apr 30, 2015 9:52 am
Yeah that's a fair point it's only my instructions are on a print out so I will have to take photos of it but that's no problem, I wasn't trying to be clever !!
dan@biali
Post by dan@biali » Thu Apr 30, 2015 2:37 pm
Have you got the part number and I'll see if it says it's got BT on etka.
Gibbo
Post by Gibbo » Thu Apr 30, 2015 2:40 pm
NornIron wrote: I have the Passat B5.5 lamp and the bluetooth mic fitted. Definitely a RNS315, part no's as requested:
stan-the-man
Post by stan-the-man » Thu Apr 30, 2015 3:23 pm
If the case was swapped over only vcds will tell the true part number. Fingers crossed its not the case
dan@biali
Post by dan@biali » Thu Apr 30, 2015 3:43 pm
In theory that is a bluetooth enabled RNS315. Etka says it has 'preparation for telephone with voice control without 3 key module'.
As for the case being swapped, don't these have anti tamper stickers on the screws so you would know for sure if it had been opened.
Caddymat
Post by Caddymat » Thu Apr 30, 2015 4:07 pm
The MAC address is all zeros therefore has no internal Bluetooth, if the Mac had a numeric value it would have Bluetooth
stan-the-man
Post by stan-the-man » Thu Apr 30, 2015 4:11 pm
I think theres only couple of sticker strips along the body that would obviously have to be broken.
dan@biali
Post by dan@biali » Thu Apr 30, 2015 6:00 pm
You're right caddymat - all zeros in the mac address means no bluetooth.
Caddymat
Post by Caddymat » Thu Apr 30, 2015 7:08 pm
Only reason I know is im currently trying to install the same head unit in my van, mine has a MAC address so has the built in Bluetooth, problem is the phone button just mutes the unit, sat nav works a treat but the DAB radio is not accessible either?
Think I need to find somebody local with vcds to activate it
Who is online
Users browsing this forum: No registered users and 0 guests
