Steering wheel off centre
Pinch
Post by Pinch »
As above, my wheel is off centre when the wheels are straight. However, going full left to full right has the wheel in the same position at full extension.
Tracking? Or get the wheel off and realign?
geezer
Re: Steering wheel off centre
Post by geezer »
I'd take wheel off and realign, has it been taken off at any point?
gprent
Post by gprent »
no no no no....... leave the steering wheel where it is, and go get the tracking done.
lots of safety issues regarding steering wheel removal. there's absolutely no need to do it unless someone has tacken it off without your knowing.
Pinch
Post by Pinch »
Well, it has a touran dash so at some point the wheel has been off.
Lock to lock and the wheel faces down both sides.
Tracking I feel. Will update when inspected. I don't fancy getting the wheel off. My Touran is awaiting a cruise control stalk, had the wheel off before to inspect. PITA.
dubvan
Post by dubvan »
I've had my tracking done twice and wheel isn't straight, grates on my OCD like you wouldn't believe. And they even used the wheel clamp between steering wheel and seat!!! :evil:
torque777
Post by torque777 »
I have same issue, I've had tracking done a few times and not got it right yet, I just live with it now lol
horace01
Post by horace01 »
First thing I would do is remove the airbag and check the marks on the wheel and the hub are aligned.
If they are then start looking at other issues.
I had tracking and alignment done and was pretty much told that "all VW's are like that" Won't be going back to that place again!
In my case I needed to recalibrate my steering angle sensor with VCDS .
Euro Technika
Post by Euro Technika »
Yep Horace is 100% correct
dubvan
Post by dubvan »
Ah, I might ask dealer to do that next time the vans in. Cheers, Horace.
