Bls engine
Caddyslack
Re: Bls engine
Post by Caddyslack »
These were the Bigend bearings of cilinder 1 & 3 of our Caddy BLS-Engine: https://www.facebook.com/30265462646631 ... =1&theater
In the opinion of my mechanic are the bigend bearings the cause of many BLS-engine crashes
Our Caddy has now the bearings from the older engines (called Sputter bearings). :D
Our Super Family Car
1.9TDI (BLS) @ 162Hp&360Nm - 5-Speed gearbox (GQQ) - 18" OEM Bristol wheels - Golf MK7R front brakes -Premium cluster - Offroad Grey metallic
gti_james
Re: Bls engine
Post by gti_james »
I'm viewing a 130,000 mile Caddy (07) with a BLS engine tomorrow. Is there anything I should look for or ask the owner? Thanks.
emurray89
Re: Bls engine
Post by emurray89 »
Caddy is back in my possession.
The donor Engine was a Mk4 Bora Tdi ASZ 130 with 98k on the engine, Cant really say much Its been mapped out with an economy remap and i have to say its 100 times better than my BLS engine ever was. Love having that extra bit of power, going for the bigger turbo and egr delete next. 8)
Overall very happy with the results!
rsjohn
Re: Bls engine
Post by rsjohn »
Its good to know that an earlier mk4 platform engine will fit, did they say what the head gasket and bolts that were used plus any modifications they had to do to fit?
fxy
Re: Bls engine
Post by fxy »
hi mate, im glad you got it all sorted in the end ,did he use all the 130 engine or just the bottom end ? and what did he do to it to make it work ?
thanks foxy
emurray89
Re: Bls engine
Post by emurray89 »
He's used pretty much all the engine minus the rocker cover, Still running my turbo egr ect believe he also had to fabricate a few pipes.
It does belch out a bit of black smoke when the foot is flat due to having bigger injectors and my old turbo. Going to fit the pd 130 turbo and blank off the egr and that should sort it out.
If anyone is after any information give him a ring he's spot on!
Caddydaft
Re: Bls engine
Post by Caddydaft »
Had a problem with one of these engines before and it was No. 3 small end bearing had broken up. The guy that owned the car before was putting the wrong oil in to it. Took a bit of head scratching to find. Might be of some use to someone?
gti_james
Re: Bls engine
Post by gti_james »
Any of you boys running a single mass flywheel on your bls engines?
gilly
Re: Bls engine
Post by gilly »
Good to see you got there in the end,what was the finale cost for the engine and all the work you had to do?
