Touran Front Bumper
Royster1984
Touran Front Bumper
Post by Royster1984 »
After a little advice, I ve had a touran front bumper fitted by a local bodyshop. Should it fit perfectly the sides just seem to hang a little I ain't sure if the bodyshop has incorrectly fitted it??
anthony
alarmfitter
Re: Touran Front Bumper
Post by alarmfitter »
That's wrong it should meet the wing properly is it genuine vow or a pattern part ?
Royster1984
alarmfitter wrote:That's wrong it should meet the wing properly is it genuine vow or a pattern part ?
Genuine part
alarmfitter
I think there is a bracket on the wing they could of missed but anyway a decent body shop wouldn't give it back like that
dan@biali
Post by dan@biali »
I think there's a bracket which the bumper kind of slides into along the side and then you push it in to finally engage. I suspect it's not been installed properly by the bodyshop.
mkvanman
Post by mkvanman »
Male & female slots on bumper /wing also 2 small black pin type fittings on wings near the wheel arch.
alarmfitter
That's poor workmanship
Royster1984
Thought so, they was 4 commended by a friend too. Won't be going back there again.
alarmfitter
Go back and get them to do the job properly first
paul4314
Post by paul4314 »
looking at that it should be a matter of sliding it forward and slide it on correctly
easy diy job if u have some basic torq screw bits
the only worst possible case i can see with it is that i have seen some of these that have lost the brackets that are moulded to the bumper itself but that is worst case but defo take it back and make them put it rite
