The seats won't line up with the back bolt holes, vhowever you'll notice that there is a hole in the seat rail that lines up with the big hole in the base. You use the standard seat bolt, a nyloc nut and make up a washer out of flat steel, with a 10mm hole drilled. It had to be big enough to cover the hole. I'll try and find my photos soon.Waterboy wrote:
Hello. I am also going to fit R32 seats and was looking at Touran bases. I don't care about the seating height so I was wondering if you could explain a bit more about these washers. I know the lugs have to be ground off the rails but thought I have to mod the Caddy bases. If I don't have to....I'm all ears (eyes).
Sent from my Nexus 6P using Tapatalk
