Caddy Maxi Life mats part numbers?
Aikon
Post by Aikon » Sat Mar 04, 2017 1:59 pm
I'm looking to order a set of rubber floor mats and a boot liner ready for my Caddy which should be here in the next few weeks & wondered if anyone could help with part numbers?
I've ordered a seven seater but will be taking out the rear two for daily use and folding forward the middle three, ideally I'd like front and rear rubber footwell mats for the 5 seats, and a boot liner for the load bay and underneath the middle row of 3 seats for when they're folded forwards, does this combination exist and can anyone help with the part numbers?
TIA
Maxi4life
Re: Caddy Maxi Life mats part numbers?
Post by Maxi4life » Sat Mar 04, 2017 2:13 pm
That's exactly what I wanted but couldn't find. Ended up buying 5mm checker plate rubber mat from ebay and plan to use my rear ply lining plus some cardboard to make a template for cutting.
Aikon
Post by Aikon » Sat Mar 04, 2017 2:26 pm
I found this on ebay but it's for a Caddy Maxi, not the Life & I don't know if the additional trim on the Life interior is enough to make it not fit.
http://www.ebay.co.uk/itm/161716529209" onclick="window.open(this.href);return false;
Sent from my F5321 using Tapatalk
Burly Chassis
Post by Burly Chassis » Sat Mar 04, 2017 2:55 pm
Hi Aikon, I have been looking at the same bits; here are the part numbers from the accessories price list:
Flexible load tray Caddy Maxi Life
2K3061161A
£107.00
Heavy-duty rubber floor mats:
Front
2K2061501A041
£38.00
Rear
2K006151282V
£35.00
Aikon
Post by Aikon » Sat Mar 04, 2017 5:12 pm
Awesome thank you!
Burly Chassis
Post by Burly Chassis » Sat Mar 04, 2017 5:53 pm
Pleasure!
Aikon
Re: RE: Re: Caddy Maxi Life mats part numbers?
Post by Aikon » Fri May 05, 2017 4:37 pm
Burly Chassis wrote:Hi Aikon, I have been looking at the same bits; here are the part numbers from the accessories price list:
2K3061161A
£107.00
Front
2K2061501A041
£38.00
Rear
2K006151282V
£35.00
Many thanks for these, picked the Caddy up this week, VW dealer said they only make front mats for the Maxi Life...
Local TPS found them on ETKA from your part numbers and I've just fitted them, the rear footwells needed trimming slightly as they fit two models apparently, the boot tray goes right under the middle row seats and fits pretty well, the middle row seat mounts aren't quite where the VW cutouts are but it's close enough to keep the mud off the carpet!
I've added some photos so others can see what you get from these part numbers!
1. Full boot, middle row folded and tumbled
2. Mid boot, middle row seats in use
3. Middle row mats
4. Front mats
I won't be using the rear bench (seats 6&7) but the cutout guides are there if you need them. I've wrapped mine in pallet wrap to put back in when I sell it as a taxi in 3-4 years time! ImageImageImageImage
torque777
Post by torque777 » Fri May 05, 2017 5:20 pm
I have same footwell mats in my life, still going strong after 3 years
ysub
Post by ysub » Wed Aug 23, 2017 9:43 am
Hello.
I'm looking for a load tray mat for my 2015 caddy maxi.
I've seen the picture posted by Aikon, that's what i'm looking for?
I was just wondering, is this mat made of heavy rubber like the footwell mats, or is it a foamy light material like sone other tray mats i had from VW?
Thanks for the answer.
Gaj69
Post by Gaj69 » Fri Aug 25, 2017 10:15 pm
The load tray is hard plastic, I have one in my short wheelbase life, it's ok but not great. The foot pats are great. I'm considering getting some rubber for the rear floor.
Aikon
Post by Aikon » Mon Aug 28, 2017 7:09 pm
Yup it's hard plastic, and the cutout guides aren't quite in the right place so check carefully before you cut if you get one.
PaulC61
Post by PaulC61 » Thu Aug 31, 2017 9:02 pm
Nice load tray. I cannot find one like that for my Kombi where the tray goes right under the seats. Would be great for when the seats are folded forward and the bikes are inside.
thebackrow
Post by thebackrow » Wed Jun 12, 2019 3:16 pm
2K3061161A
£107.00
I think that might be the wrong code.
https://shops.volkswagen.com/assets/MAS ... NG_002.pdf
Looks like there may be two models of this - one for the Life with the plastic interior and one for the stripped down Kombi van without. That might explain why mine doesn't fit.....
