2016 lowering and wheels?
Beanieuk
Post by Beanieuk »
Hi all
New Caddy owner here so please be kind :D I pick up my 2016 caddy highline next week and look for info on lowering the newer caddys and what size wheels to go for. I will be my daily driver so will do around 18k miles a year, I won't have much weight in the back just some hand tools and my mountain bike from time to time.
Don't want it super low just a good daily driver so any info from people that have already done it would be great.
Beanie
Scrabby67
Re: 2016 lowering and wheels?
Post by Scrabby67 »
My 2017 van lowered with the 45mm Eibach kit. Standard VW Canyon alloys 17". Drives and handles better than when it was new now it's lowered 45mm.
Beanieuk
Post by Beanieuk »
Great just what I was after, cheers for the photo. I have seen the 45mm kit so will get that one. 17's look good to. Your van looks lovely :D
B18oam
Post by B18oam »
18" lowered with a JOM coilovers and axle flip kit. Practical a little more bouncy than I was hoping for on harsh bumps but they were about a quarter of the price of Bilsteins.
Matt2kn
Post by Matt2kn »
Beanieuk wrote:Hi all
Beanie
Here is mine on 19s and on kw coilovers. Ride is superb.
Sent from my EVA-L09 using Tapatalk
LTCKY
Post by LTCKY »
Mine on Eibach and 19" wheels, not as bouncy as coilovers. Haven't noticed much difference from 18"- 19". I do about 18000 miles a year and carry a bit of weight.
Shocks Away In Car Solutions
Car Audio Specialist
Shocksaway.com
Matt2kn
Post by Matt2kn »
Apologies just noticed my previous picture did not attachImage
Beanieuk
Post by Beanieuk »
Cheers guys, mind has been made up I am going to go with the Eibach kit. Now just got to make my mind up on what wheels
Richie_VW
Post by Richie_VW »
What come with the eibach kit? Just springs? Do these replace the leaf slings on the rear?
2015 Silver SWB Highline 102ps, Day van, MTB overnighter..... with Onsuite
Scrabby67
Post by Scrabby67 »
Richie_VW wrote:What come with the eibach kit? Just springs? Do these replace the leaf slings on the rear?
You get the front springs and the rear axle flip kit, you move the springs from above to below the axle. The rear shackles are the adjustable to lower by 45mm minimum but can go a lot lower.
tonyg1985
Post by tonyg1985 »
My preference is an adjustable coil over kit with the shorter rear dampers included. Lowered to 60mm with 18" wheels looks spot on!
VMAXX is a decent kit but around £400
Blueline is a cheaper alternative at around £270
Maxi4life
Post by Maxi4life »
Watch it with the shackle kits. My advice is get a kit from darkside because they do different plates now that allow for every type of leaf spring you may encounter, and if it turns out you need offset plate to centralise the wheels Darkside will let you return the plates you don't need and give you the ones you need to get it right.
Also you might find that If you have a maxi then you might be on the highest setting on the shackles to sit level with the fronts on springs. Although plenty low enough for me with 19's looks just right without being decked into the speed bumps and pot holes.
Darkside kit plus Eibach or H&R springs will be £300 inc VAT Same price that the Eibach kit costs.
DJOHALL
Post by DJOHALL »
Matt2kn wrote: Mon Aug 14, 2017 11:58 pm Apologies just noticed my previous picture did not attach[IMG]htt7ps://uploads.tapatalk-cdn.com/20170814/8271f7834e00df1276e35ccfb7397784.jpg[/IMG]
What bumper have you on your van?
peres92
Post by peres92 »
Hi, I'm looking for advice with wheels too, I will be going for 18/19, but I'm not sure how wide to go.. will caddy take 9j? if yes what ET they need to be?
:mrgreen:
Swik
Post by Swik »
For Scrabby67:
Would you be able to attach a photo of the underneath rear suspension setup (after being lowered)?
Did you cut down the bump stops?
Where did you buy the kit from?
Thanks in advance
