Retrofit MFSW parts help - VCDS log included
Cammy
Post by Cammy »
Hi everyone, I recently got myself a MFSW which I want to fit pretty soon, however the MFSW information is literally a minefield and with some of the information being hosted by photobucket (which cannot be viewed unless that person was verified) im finding it hard to gather all the information I need.
I didn't opt for the flatbottom steering wheel - instead I got a normal MFSW with gloss black trims, as far as my van goes - have a basic instrument cluster, but I do have cruise control as standard - so im presuming all I will need now is the MFSW/Highline slipring, re-adapt the SWCM/angle sensor (g60) and then I should be good to go, and further down the line I can get the highline clocks, and an RCD 510 to help me function everything through the wheel and instrument cluster?
the slipring comes back as a 5K0 953 549
And my collumn controls come back as the following 1k5 953 507 P
But if anyone is so kind enough to have a look through and let me know if I need to change my column switches (I just have the basic ones, can get numbers if required) and whatever else I will need for this to fully work it will be appreciated
For the record, mine is a facelift 2011 Caddy Maxi
Code: Select all
Wednesday,13,September,2017,17:19:24:30069
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WV1ZZZ2KZCX073515   License Plate:
Mileage: 150280km-93379mi   Repair Order: MFSW-1
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56 61
VIN: WV1ZZZ2KZCX073515   Mileage: 150280km-93379miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 PD    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 0870
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114010032501080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023PD 003003
   ROD: EV_ECM16TDI02103L906023FL.rod
   VCID: 77AA1969AF4A13EF6A0-8022
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 633C400D092903FDC61002E5901EC091310000
   Shop #: WSC 35110 377 08192
   VCID: 7BA2055993E2378F0E8-802E
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 5K0 937 085 R    HW: 5K0 937 085 R
   Component: BCM PQ35 B+   021 0064
   Revision: BB021001
   Coding: 491A583A8037F12B08800082900000640381728842020060648087000041
   VCID: 42DCB8BDB48886470DE-8016
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 04101  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 7N0 951 171
   Component: DWA-Sensor 00  002 0205
   Coding: 000000
   Subsystem 3 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Coding: 000000
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag00V H06 0013
   Revision: --------    Serial number: 003HL008KJ13
   Coding: 000000000000000000000000000000003056
   ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3536D361F5C621FFB8C-8060
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 1K5 953 507 P    HW: 5K0 953 549
   Component: Lenks.Modul   008 0080
   Revision: --------    Serial number:  90440KJK000BJ
   Coding: 0080160000
   ASAM Dataset: EV_SMLSNGKUDS A05001
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 3E24CC4DC0F0E2A7696-806A
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 2K0 920 965 E    HW: 2K0 920 965 E
   Component: KOMBI         H03 0606
   Coding: 480201
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_004_VN35.rod
   VCID: 313EE77101AE0DDFE44-8064
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 N    HW: 1K0 907 951
   Component: J533  Gateway H43 1623
   Revision:   H43       Serial number: 191011F1001644
   Coding: 357401
   VCID: 3B22C559D362F78F4E8-806E
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0606
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6A8C301DECF8BE07E5E-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 74 0160
   Coding: 0000004
   VCID: 76B4146DA4C06AE7716-8022
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 140    3301
   Revision: 00H22000
   VCID: 3536D361F94621FFB8C-8060
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Component: Tuersteuergeraet 02 0160
   Coding: 0000004
   VCID: 75B61361B9C661FF78C-8020
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 156 A    HW: 5K0 035 156 A
   Component: Radio         553 0555
   Revision: R0553006    Serial number: VWZ5Z1L0596893
   Coding: 0500020001
   VCID: 2516032145E6517F08C-8070
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H43 1623
   Coding: 030F185A
   VCID: 71BE2771C1AE4DDFA44-8024
   Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900770329
End----(Elapsed Time: 00:58, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Re: Retrofit MFSW parts help - VCDS log included
Spacewalker's How-To thread is very good, even though it was written for the pre-facelift model.
It has a link to the list of part numbers of the modules you need along with information of airbag compatibility and harnesses.
Cammy
Post by Cammy »
Thanks doc! I seen that thread before but couldnt find it again - thanks for that.
I think i have everything, ive got the steering wheel, and airbag coming, also have a new highline module from VW coming - so ill see how i get on.
Expensive play just to have a few more buttons!
Wow, it certainly is expensive when you go to VW for new parts.
Cammy
Post by Cammy »
I only got the slip ring new, the air bag plus the loom, and the steering wheel were second hand but both look brand new
The slip ring was £149 though, there was a unbranded version new for £58 - but i thought with the retrofit i would be best getting a genuine one for reliability and incase the unbranded one gives any problems with retrofitting, knowing my luck it would :roll: :lol:
All in all, about £450 to get some buttons :roll: thats not counting still needing to buy an MFD cluster, and a RCD 510 and fiscon bluetooth :lol:
Dmilnes83
Post by Dmilnes83 »
Hi all.
New to the forum so please go easy on me :roll:
I have purchased a 2K 2008 model for my business. Few mods including audi TT seats. Window tints. Lowered on coil overs usual bits.
I'm having a problem with the steering wheel that is in the van. It has a GTD flat bottom Mfsw however who ever put it in didn't bother to wire anything up. Or they tried and couldn't find anything to work. So my main thing is getting the horn to work as I feel this is an essential part of a car that has to work :lol:
Any information will be great.
Thanks in advanced
Monkey_22
Post by Monkey_22 »
Hi mate what was the part number of the slip ring you used?
