My £500 sdi
DM01
Re: My £500 sdi
Post by DM01 »
Great work
Mk2kompressor
My £500 sdi
Post by Mk2kompressor »
Collecting some parts tonight £200 for all in the pic! Image
Front rad panel is currently held in place via superglue and camo gaffer tape, hopefully this one fits Image
2.Slow
D green
Re: My £500 sdi
Post by D green »
Wow what a bargain you really got all that for£200 were from
Mk2kompressor
Re: My £500 sdi
Just got home with it all, found on the shpock app, 4 pod lights (hopefully plug and play) even the radiators!
2.Slow
D green
Re: My £500 sdi
Post by D green »
Would never of thought to look on there nice touch
D green
Re: My £500 sdi
Post by D green »
Mite have to keep an eye on there
Mk2kompressor
Re: My £500 sdi
Ok, electrical question:
I have touran wings as above with no side rep holes, currently I don’t really want or need elec windows but I assume the door modules from a touran are needed to run the touran mirror reps?
Just thinking do I really need to do the work for the modules (if so fit elec windows) or I could just cut new holes in the wings and run some different side reps
2.Slow
Re: My £500 sdi
I'm fairly sure there are door control modules without electric window motors which have the necessary outputs for wing mirror repeaters.
Only one sure fire way to find out, it'd take all of 10 minutes to pop the door card off and check the part number and pins. You need it off to fit the mirrors anyway.
Mk2kompressor
Re: My £500 sdi
Thanks doc, even caddy modules?
2.Slow
Re: My £500 sdi
Yup
kieronb
Re: My £500 sdi
Post by kieronb »
Love the reoccuring bargains you keep finding! Keep up the good work!
:shock:
Mk2kompressor
Re: My £500 sdi
Doc,
Will these also run elec window motors?
2.Slow
Re: My £500 sdi
I'm not near my computer to check.
Are they attached to motors?
As a rule, if the door control module is not attached to a window motor, it's not capable of running electric windows.
D green
Re: My £500 sdi
Post by D green »
How's the rest of the build going by the way have you managed to get the front end on yet
Mk2kompressor
Re: My £500 sdi
Poverty spec windy doors atm.
I'll get modules when I fit the Windows then
Working on getting paint for the front end, I have to plan everything out before I do anything.
Combo of ptsd and aspergers
2.Slow
