Tp's Caddy conversion
Liam
Re: Tp's Caddy conversion
Post by Liam »
those seats are a bargain
Build thread here
Ddraeg
Post by Ddraeg »
Tp88 wrote: Fri Jun 15, 2018 7:40 am Thanks! The bed admittedly is going to be slightly thrown together and not quite as fancy as many that I’ve seen! So long as it does the job though.
A mattress in the back will be sufficient!
Liam
Post by Liam »
self inflating air mattress and you can have comfort and not have to lose space in the rear of the van - roll it up and put it away when u dont need it
Build thread here
NZDubNurd
Post by NZDubNurd »
Liam wrote: Fri Jun 15, 2018 8:55 am self inflating air mattress and you can have comfort and not have to lose space in the rear of the van - roll it up and put it away when u dont need it
Air ride :lol:
Liam
Post by Liam »
exactly
Build thread here
Tp88
Post by Tp88 »
Side door now cladded
Seats going in on touran bases
Tp88
Post by Tp88 »
Makes such a massive difference!
Liam
Post by Liam »
looks really good must look out for a set of touran bases myself
Build thread here
Tp88
Post by Tp88 »
It’s not pretty but hopefully it’ll do the job. I’ve built it in two sections so if I still need to use it to love stuff around I can just remove a section...
Tp88
Post by Tp88 »
Made heaps of progress today. Chuffed it’s all working out!
So... bed ply on.
Then thw start of a pull out draw for coffee and storage
Magnetic curtains went up today too.
And finally just before dark, a coat of absolute black.ImageImage
A lot of it is very much rough around the edges. Plan is to throw it together as I’ve done now, re build it in the future but with a week until we set off to do the North Coast 500 I’ve nae had much choice.
Also was chatting with my neighbour about coil overs, he’s persuaded me to investigate lower springs and new dampeners (not sure if that’s what you call them? Bit in the middle of the spring) and potentially the lowering rear end from darkside or an axle flip. All of which i have absolutely no idea on and will probably come next year when I can afford that and some 18” alloys!
Next job is power...
The USB port into the radio continues to be intermittent and to add to my 12v power torment the loom to the cig lighter doesn’t seem to be throwing out power either. Very annoying!
Liam
Post by Liam »
eibach lowering kit uses shorter front springs and pretty much the same rear axle fit thing as every other kit and u can keep standard shocks
Build thread here
Tp88
Post by Tp88 »
Liam wrote:eibach lowering kit uses shorter front springs and pretty much the same rear axle fit thing as every other kit and u can keep standard shocks
Great shout-thanks! They’re not cheap are they!!!
Caddyluv
Post by Caddyluv »
I think vanstyle do them for around £400 which includes fitting.
Tp88
Post by Tp88 »
Couple of finishing touches...
I couldn’t make any sense out of trying to get the USB port to work from the head unit, nor could I get power from the coverage lighter loom so I decided to quite my loses and take power from the fuse box and use a double USB cig charger.
Next on the list was LED lights. I did a fair whack of research and came to the conclusion LED strip lights don’t take a great deal of power so in theory (famous last words) won’t drain the battery.
Electrical wiring baptism of fire... planned it out all on paper, bought a soldering iron electrical tape etc...
Taking power from the rear light, I wired it all up to a switch above the side door and put the stripping on the back of the top wood cladding.
When I was testing out before soldering all the parts I accident hit power to earth and blew the 7.5 fuse. I’d got so far and didn’t really want to give up given we’re departing on Friday so with a wee bit of googling I came to find using 10amp wasn’t going to destroy anything (hurra!) and I can nip to halford tomorrow and pick a new one up knowing it all works.
Chuffed to bits with this finishing touch.
Oh and we went to Ikea to buy a bed which fits perfect! So satisfying!
Ddraeg
Post by Ddraeg »
Ahhhhh that well known bed fitting tool, the hammer!
Looking excellent, I hope your trip goes well.
