Mountain Bike/Day Van Daily Driver
caddychris2002
Re: Mountain Bike/Day Van Daily Driver
Post by caddychris2002 »
Caddyluv wrote:Fit the board so you know where your holes are. Counter sink the hole on the board so the screw isn’t as proud. Stick the carpet, cut a small line over the hole when tacky. Screw back on, then put glue on a tooth pick or something like that so you don’t get glue on the carpet. Lift and stick push the carpet back together.
Cheers Caddyluv you've done that before lol
www.dav-tec.co.uk
www.facebook.com/davteceng
Autowatch Ghost Installer
Mods:
Caddyluv
Post by Caddyluv »
No I like contrast on mine.
Black caps black roof.
caddychris2002
Looks bang on that pal
www.dav-tec.co.uk
Mods:
Golfchick
Post by Golfchick »
Caddyluv wrote: Thu Jul 19, 2018 11:01 am Fit the board so you know where your holes are. Counter sink the hole on the board so the screw isn’t as proud. Stick the carpet, cut a small line over the hole when tacky. Screw back on, then put glue on a tooth pick or something like that so you don’t get glue on the carpet. Lift and stick push the carpet back together.
Ahhhh ace good idea and know what you mean!
Caddyluv
Post by Caddyluv »
If you get glue on the carpet wd40 will get it of. Or upol degreaser.
caddychris2002
Progress update today i upgraded the headunit complete with GPS and DAB aeriels. Tried to make it look factory as possible even made my own USB socket just awaiting for my reverse camera to arrive. Android Auto is epic!
One question does anyone know which wire at the back of the light switch i can come off for the feed from the side lights to the illumination wire on the backof the head unit. TiAImageImageImageImageImageImageImageImageImage
www.dav-tec.co.uk
Mods:
No need to go to the light switch to pick up a illumination wire, the climate panel and the traction control button both have this right beside you.
It's a grey wire with a blue trace.
caddychris2002
Doc wrote:No need to go to the light switch to pick up a illumination wire, the climate panel and the traction control button both have this right beside you.
Doc you the man cheers pal
www.dav-tec.co.uk
Mods:
caddychris2002
So got all the alloys done now and got the roof insulated with that foik wrapped bubble wrap stuff just the rest of thw van to insulate next.
Got the rear camera installed but new problem got an image fine with the ignition on but as soo. As the engine is running the image disappears as if I've got interference any ideas anyone?
Also how the hell do i get access to all the other areas i this group like engine and electrical etc TiAImageImageImageImageImage
www.dav-tec.co.uk
Mods:
Where did you pick up the power for your rear camera? I suspect the reverse light, in which case it has been discussed more than enough times on this forum, there's no need to go through it again.
This might be of interest to you to gain more access to this forum. www.caddy2k.com/newmember
caddychris2002
Doc wrote:Where did you pick up the power for your rear camera? I suspect the reverse light, in which case it has been discussed more than enough times on this forum, there's no need to go through it again.
Aha Cheers Doc should of read that when i signed up. Sorry about that.
Originally it was one of the rear wiper wires but turns out that that wire looses power the minute the doors shut and the ignition is turned off. To get power back you have to put ignition o. And have the door open. So yeah i decided to spur off the reverse wire... back to the drawing board.
Cheers pal sorry for my muppetry lol
www.dav-tec.co.uk
Mods:
VolksVan1890
Post by VolksVan1890 »
caddychris2002 wrote: Thu Jul 12, 2018 3:40 pm So I thought I'd start a build thread. My 2013 1.6 102 in some vw gun metal colour (of which is to be identified). Sat on BBS CH Alloys lowered an unknown amount on coilovers
Plans are.
Respray Alloys Bronze or Gloss Black
Insulate/sound deaden interior
Ply and Carpet interior
New Android Auto compatible head unit complete with reverse camera and underseat sub
Touch up bad parts of paint work
Either new front bumper from 2kcaddy on instagram or respray it and do the plastics gloss black
Xenon head lights
Mk7 golf steering wheel (have the wheel but need everything else) and get steering controls and cruise co trol working.
Full interior and exterior detail
Thats it for nowImageImageImageImage
have you got spacers on them wheels? as I am looking to get 18x7.5 et51 wheels myself. thanks
caddychris2002
No pal they're 18x8 et4# It says on the back not sure what the second digit was
www.dav-tec.co.uk
Mods:
caddychris2002
So yesterday me and my mate Lee did a full exterior detail of the vans bodywork. I've got to say wjat a difference the paint is glossier and the pop from the paint work is brilliant.
Lee did say that VW is the hardest paint he's detailed and he's do e Jag's Audi's BMWs all sorts.
Couldn't get all the marks out and some off it will require respraying at a later date but for now it looks a lot better and the paint work that is good is protected.ImageImageImageImageImageImageImageImageImage
www.dav-tec.co.uk
Mods:
caddychris2002
A few pics today now the hydrophobic coating has cured so impressed with the resultsImageImageImageImageImageImageImageImageImage
www.dav-tec.co.uk
Mods:
