Metal behind front seats
My caddy 17 plate has just metal behind the front seats on the floor pans is there any rubber options for these as it’s a bit sparse.
Re: Metal behind front seats
Anyone?
The early Caddys had carpet on this section.
It's a seats out job to fit it properly.
I expect you can find it from most Caddys that are in breakers yards for not much money.
- Beaker2135
I had a foam tile left over from doing the garage floor I just cut that up. You can buy a set of 6 tiles 600mm square for less than £10
