Stormtrooper caddy 4 build
mark1a
Re: Blue obsession caddy 4 build
Post by mark1a »
Caddyluv wrote: Mon Nov 19, 2018 8:13 am @mark1a I have got the wife to put her foot on the break. But the brightness I don’t think it’s different. Just the light colour is. So it feels different. I’m say no there isn’t any brightness difference.
OK thanks Ryan
Caddyluv
Post by Caddyluv »
Once I’ve found a solution for the 3rd brake light you can probably have this one. As you say it will look better on the Blackburry defo.
Giddy
Post by Giddy »
I have used Lamin-x film to tint the rear lights on my previous car. This might be an option, but its hard to tell from the pictures which shade you may need. I have used 6% and it gave me nice dark-ish red.
https://www.funkmotorsport.com/product- ... -x-sheets/
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
mark1a
Post by mark1a »
Caddyluv wrote:Once I’ve found a solution for the 3rd brake light you can probably have this one. As you say it will look better on the Blackburry defo.
Thanks for the offer, but I have a tailgate not barn doors, so I expect fit is different.
Caddyluv
Post by Caddyluv »
@mark1a
Yeah it is. I forgot, I did know that. 🤦🏻‍♂️ Soz
@Giddy
I have thought about film. I have a couple of issues with that.
1 over time it will Matt and need replacement time and time again.
2 the shade will be total guess work.
3 I only need 1 inch x 3 inch bit.
So what I’m possibly looking at is putting some black paint in so gloss to tint it that way so it stays glossy and I can keep it glossy.
Caddyluv
Post by Caddyluv »
So replace my subframe bolts today hopefully it sorts out the clunk.
Sabbunsingh
Post by Sabbunsingh »
What's the undertray from? Any part numbers? Thx
Caddyluv
Post by Caddyluv »
It’s for a caddy 4 it's 2K5825453
Caddyluv
Post by Caddyluv »
Been having a little trouble with my folding caddy life mirrors, since I done the LEDs in the door cards. I guess it was when I took the plugs out the module. They were working fine on the switch but intermittent on the key. So I thought I would see if I opened and closed them, relearn like you do with the windows. So I did it 3 times. So far works amazing has done for 4 days now. I don’t know if this is common knowledge but it’s worked for me.
Caddyluv
Post by Caddyluv »
Done couple things today. Before lunch. ImageImageImage
Silicon hose between bulkhead and B pillar stop the new squeak. Hidden away fingers crossed. ImageImageImage
Tinted rear reflectors fitted. Soooooooo much dirt. That must of saved some MPG.
Done few stone chips on the front. Not a lot today but those fussy little things you want to do but can’t be arsed.
Caddyluv
Post by Caddyluv »
So as you know I put in a van x third break light and I didn’t like it. To black didn’t look like the factory rear lights. So today I got some smokey tint.
First go I used the heat method. It left micro bubbles. So I used the soapy water method with heat. Which worked better.
If you look close on the finish edge. Just left it to cool and it’s stuck the edges properly.
Liam
Post by Liam »
looks good ryan
Build thread here
Caddyluv
Post by Caddyluv »
So today thought I would use my Xmas pressy.
Started with snow foaming then soft mit wash.
Then upol the panels. Then took all day 3 stage polishing the van with two coats of HD Autoglym the two coats of Autoglym shine protection.
Liam
Post by Liam »
oooh shiney
Build thread here
Caddyluv
Post by Caddyluv »
It is isn’t it. Need to do roof that’s all that’s left to do.
