Few quick shots of them fitted in the light !
Ride Bikes Drink Beer
- Liam
looking good when are you lowering it
Build thread here
Build thread here
Tired of the lack of light in the back of the van so made some windows in the bulkhead. Just 3mm polycarb nut and bolted in. Need to tidy up the edges and run some silicone round but should do the job
- The polisher
Looking good m8 ,a bit of Black rubber trim around the edge would finish it off
Touran seats, Touran Console, Touran carpets, Touran Door cards, Spoiler, German Plates, RCD 330, carpeted and insulated, TDI Mats, Stance lowering Kit, VW Mk6 Steering wheel, T6 Steelies, Bargain Sunvisor, Bragan Roof Rails,Touran mirrors
Instagram:HG_Metal_Polishing_13
Facebook: HG Metal Polishing
www.hgmetalpolishing.com
Ireland
Ireland
I've got the ST-X kit ready, just waiting for my mate to find time to sort it!Liam wrote:looking good when are you lowering it
Did you do this as a whole sheet on each side or is there some very neat joints going on there?Cheeseburger wrote:Had my first go at carpeting. Sore furry fingers but not at all a bad result I think
megavanmats smoke carpet and dark grey clips
- Rigpig
Got home from a trip offshore and stuck it straight in for a MOT, straight through with no advisories. Happy with that for a 11 year old van, only got 40k on the clock right enough.
Got hold of Stan the man for my heated seat looms, so they should be en route soon, looking forward to getting those wired in.
- JimR
Are you getting heated seats wired into the original system? This was the one comfort feature I missed to check when I got the new Caddy and I would really to get it mounted into the original seat and the original wiring if it's possible without too much work.
JimR
JimR
Today was a good day well kind of haha,
I drove 300 miles to pick up some 65 plate standard caddy seats with gte seats covers on and a van-x arm rest. This part was great nice drive down, meet a top bloke in Slough with a really nice caddy.
I fitted the driver's seat no problems but when I came to tighten the last bolt on the passengers seat rail it seemed really tight. I then took the bolt out cleaned the thread made sure it's wasn't cross threaded then put it back it in. I then got the bolt to the same part as before so I went for it and put a bit of pressure on the spanner to get the bolt to go and it went past the the hard bit, but now the bolt keeps turning doesn't get any tighter or looser and I can't get it out of the rail and because it's one of the bolts on the back end of the rail the seat will only go back so far, any idea on how to over come this. Do I need to buy a new seat base and bolt any suggestions?
Sent from my Pixel 2 using Tapatalk
- Rigpig
JimR, yeah I bought a set of Golf R heated seats, and more recently picked to a replacement heater / AC control panel with heated seat controls. Got in touch with Stan the man on here and he’s made me up a set of looms, so will be as OEM as can be
- anoneamus
Had alloys powder coated, fitted VW mudflaps...
- Sean1066
At long last I finely go my MFSW fitted
Before
After
Glove box done
And then got the engine cover fitted
Looks a lot better now
Before
After
Glove box done
- anoneamus
Looking good! Excuse the OCD, but it looks like those vent rings need a bit of bending (so that they're flush with dash)...
- Sean1066
Yeah your right
That little f----- keeps popping out
Did your glove box come with that handle?
If not where did you get it
- anoneamus
Yeah, some gentle bending over the knee (I'm gonna put you over my knee little f----!), does the trick, just do little bends at a time, so you don't put a kink into the ring...
I got a bunch of extra handles, because they're completely crap and break all the time, so I had one sprayed to see what it would look like. I'm not totally convinced, the spray shop gave it a few goes, but couldn't get it to match the silver of the door handles and other aluminium bits (apparently the door handles are chrome dipped, which was too expensive for an experiment)...
