Mtb/surf/camp van build
Thought I would start a build thread as I’m starting to make some progress with the van. Picked it up a couple weeks ago and it’s pretty much a builders van .
In an effort to make it look a bit less White vanish, (on a budget at the moment with a house move looming) got a couple decals.
Quite like em but not 100% so might get rid eventually
Also managed to rip out the ply, put down some sound proofing and cover some of the original panels in a bit of carpet I got of Facebook for a tenner.
I’m pretty please with how it looks, will be carpeting the whole lot eventually and Still got to make a couple of panels for the tops of the sliding doors
Re: Mtb/surf/camp van build
Good work mate! Looks tidy
Started building a unit in the back to store stuff. The bed will go right up to the wheel arch so trying to make the most of the space.
Started to do a bit of insulation at the same time, hopefully get s chance to finish it off next weekend
The unit is looking like a nice tidy start.
Looking good so far.. Great alternative racking to the usual..
quick question.. How are the carpeted panels mounted? Pics would be good.
Tony
Tony
Cheers,I think it should turn ok.
If you look at the first pic I have put some pieces of ply up under the edges of the panel lip. Secured it with some no more nails to stop it shaking lose and screwed panels to that, had held up pretty well so far
Got my prototype shelves built, think they look pretty great. I will eventually add some doors them and either cover in something or remake the panels out of vaneered mdf
- aerobic247
nice work so far. check out my build http://caddy2k.com/forum/viewtopic.php?f=12&t=24530
Finished wiring up my s-line SEATS, decided to go the standalone route and just put some switches in the centre console. Also fitted some eBay special reversing sensors.
Already had a good look through you thread Mate, looks great and gave me loads of ideas. Gonna get a similar bed into mine once we have moved houseaerobic247 wrote:nice work so far. check out my build http://caddy2k.com/forum/viewtopic.php?f=12&t=24530
Added some window in the bulkhead and a cargo net to stop stuff rolling around in the back
Wired up some lights in the back, only cheap ones but they are as bright as the sun !
- Mark-Tam
Look pretty sweetnodeward wrote:Got my prototype shelves built, think they look pretty great. I will eventually add some doors them and either cover in something or remake the panels out of vaneered mdf
- Lister79
Did you just use an aftermarket kit with the original heat pads for your heated seats or have you fit the full aftermarket kit?
