VCDS
Sean1066
VCDS
Post by Sean1066 »
Hi guys and girls
How hard is it to recode using VCDS?
Is it idiot proof?
Thanks you in advance Sean
Caddy maxi 3.2 VR6 EX BG
My build thread
Liam
Re: VCDS
Post by Liam »
definitely not idiot proof you could do harm if you werent careful
Build thread here
Sean1066
Re: VCDS
Post by Sean1066 »
Thanks Liam
My build thread
Sean1066
Re: VCDS
Post by Sean1066 »
Is there anyone local to Devon that can code in a new steering wheel or show me how to do it ?
My build thread
JimR
Re: VCDS
Post by JimR »
Also consider ODBeleven, I just received mine and it looks really easy to use at first test.
I had removed the passenger seat and was driving with Airbag failure and it resets all failures at a press of one button
JimR
Sean1066
Re: VCDS
Post by Sean1066 »
where did you get ODBeleven from JimR?
can it code in my MFSW because that's what i need VCDS for :?
My build thread
Billyblunt
Re: VCDS
Post by Billyblunt »
Ooh, that's what I'm hoping for as I'll eventually want to fit a MFSW as well as seeing what I can unlock on the dash.
VOLKS HAUS
Re: VCDS
Post by VOLKS HAUS »
If you have a genuine Ross tech VCDS you can register with them and they provide user support and a great forum.
They have helped us with control maps for an Aventador.
