OBDeleven pro
Re: OBDeleven pro
I'm pretty sure you can but I need to explore it more to confirm. It certainly allows you to go in to long coding & change it so I'm assuming the answer would be yes.
- Sean1066
Re: OBDeleven pro
Do you think it could program my mfsw and dash for me to use cruse control etc.
And can it be used with an iPhone
Re: OBDeleven pro
It's only android based at the moment unfortunately. I'm hoping it does shizzle like that otherwise it just ends up being an expensive paperweight.
- Sean1066
Re: OBDeleven pro
Where do you find the codes from?
Re: OBDeleven pro
I'm hoping that if you go through the Ross Tech site there should be enough info to do what you want to get done. This is all new to me but I'm sure someone will jump in & offer some advice.
Re: OBDeleven pro
Been looking at this item ready for when I pick my van up this weekend, but what can you unlock extra on a Caddy van using this??
Re: OBDeleven pro
To be honest, it's very limited what you can unlock as it's dependent on equipment level already installed. The system uses one touch apps to unlock but only if the right moduals are there. If you have a baseline van, it's limited. I'll put some screen shots up later of the apps that are showing for my 2016 2.0l Caddy life so it gives you an idea.
- Sean1066
Re: OBDeleven pro
How can you tell if you have a baseline caddy.
Mine is an ex BG caddy
Re: OBDeleven pro
I'm guessing if you have a Highline it'll have more options than if you have a Startline etc
Sent from my ONEPLUS A6003 using Tapatalk
Re: OBDeleven pro
You can't enable what isn't fitted with OBDeleven, VCDS or anything else - well sometimes you can enable but it wont actually work.
You can change some basic preferences like how many times the indicators flash and get rid of number plate bulb out warnings, then after upgrading parts you can enable new functions. If you have a Highline you will have more preferences to play with but you still wont gain any significant functionality. Basically don't expect to get much benefit from an app without replacing parts.
You can install the OBDeleven app for free to see what one click apps are available for any vehicle, you just can't use them without buying their hardware. If you only want the apps then I don't think you need the pro version. The pro version appears to be not too far behind VCDS in capability and it's significantly cheaper, but every guide that you'll find online will be for using VCDS
Re: OBDeleven pro
@totty79, exactly. It appear great if you already have all the bells & whilstles but there just not turn on.
Re: OBDeleven pro
3vin limited vcds is around £150 (can upgrade it to 10 vin)
Re: OBDeleven pro
Just a word of warning peeps you can easily f*** stuff up. The up side is that there is a history tab which logs the previous code as you change it. Extremely useful if you hit a problem. Annoying thing is that there dosen't seem to be a coding bible like with Ross tech vcds you have to plough through the forum to find uploads from helpful users.
Re: OBDeleven pro
Used this to code my mk4 lights. Going to look into how clocks are done next
Re: OBDeleven pro
Does anyone know if needle sweep is possible with 2014 2k?
