2016 rear lights upgrade 07 caddy
Hey guys just got. Myself some oem 2016 caddy rear lights for my 07 caddy looking to Fit them soon
Any advice fitting them I know you have to re arrange the pins for what goes where any of the experts know on here is there like a diagram I need
Re: 2016 rear lights upgrade 07 caddy
Have you seen the how-to thread I did with all the details on which wires to swap and the order to do them in so as to avoid mix up?
HERE
HERE
No I did look in the how to doc but didn't see it have to go to spec savers cheers
I am also looking for the diagram. But i’m a new member. I cant see the topic how to do it.
- dan@biali
All the information is in the thread doc has linked to. Please re read the post here http://caddy2k.com/forum/viewtopic.php?f=1&t=31039 as it explains how many posts are required to view the whole forum and what could happen if you mention not being able to see the whole forum.............
Hello i’m new to the forum and would like to read about the retrofit for the mk4 rear lights!
- dan@biali
As I mentioned above, the thread is open to view once you have enough posts and have asked for your upgrade.
That will be useful for me too I feel!
I have the lights just need the instructions to change wiring
Hello ,
trying to upgrade rear lights from 2013 to 2015+, all I know is there are wire switch needed and also Central ECU coding. Anybody know the diagram how to switch the wires and which coding to use? Thank you
I have a 2013 with a single tailgate.
Am I correct in thinking that the facelift barn door LED taillights fit on my model. As the facelift tailgate ones have the curve on then
- Cabbs
GUYS......
As just said by [mention]Doc [/mention] and [mention]danbiali [/mention] there is a thoroughly detailed thread on how to do this but you must have the adequate post count to be able to get upgraded to view the info.
Read the forum rules first.
You can use double door lights from 2015+ and use them for both pre 2015 tailgate and twin door also..
I will check the wiring differencies between new and pre 2015 bulb holders and post it here. It may help
Thanks for that info.
