Security while in Storage
Re: Security while in Storage
If you lock the doors from the inside, then open only the driver's door by pulling the inside handle twice. You can then lock from outside with the key after you remove the battery or just the engine relay.
anoneamus
Post by anoneamus »
Doc wrote: Mon Dec 03, 2018 5:21 pm If you lock the doors from the inside, then open only the driver's door by pulling the inside handle twice. You can then lock from outside with the key after you remove the battery or just the engine relay.
We have a winner! ;)
This works if I set the central locking unlock to single door in the MFD. :)
