My EX BG VR6 3.2 build
- Liam
Re: My BG Caddy maxi build
its gonna totally transform the look of it
Build thread here
Build thread here
- Sean1066
Got my caddy lowered today. With a vmaxx coilover lowering kit.
I’m thinking the back could go a bit lower! But I will give it a couple of weeks and see what the ride like.
It’s starting to look good
- Liam
back needs to drop at least 1 hole did u cut the bump stops ?
Build thread here
Build thread here
- Sean1066
It's got one more hole to drop.
I think it needs that it needs to go to that hole and get the bump stops cut
- Liam
looks real good tho
Build thread here
Build thread here
- Sean1066
Thanks Liam
I'm trying to get it away from the BG look
But I think the colour is a dead giveaway
- Liam
GrittyBass not britishGas
Build thread here
Build thread here
Nice looking van mate, I’ve got an Ex BG maxi too. Saw one near ours a while back, that had been colour coded, with a colour coded roof box on. My jaw hit the floor!
- Sean1066
There are a lot of Ex BG van where I live. some have had bumpers colour coded.the swan fiend wrote: ↑Fri Dec 07, 2018 6:40 am Nice looking van mate, I’ve got an Ex BG maxi too. Saw one near ours a while back, that had been colour coded, with a colour coded roof box on. My jaw hit the floor!
But I have never seen one with a colour coded roof box.
It was the first and only one I’ve ever seen. Looked the biz!
- Sean1066
So just an update on what I've been doing
Window switches arrived the other week with then new door handles.
So I got round to fitting them today.
- Sean1066
But the best thing I got done was fitting the Audi TT air vents.
(Well I think it the best thing I've done today)
I started with this and had to adapt it so the TT air vents fit
Had to do a lot of cutting to get to look like this
When I finished all 4 I put them in.
And what a difference it makes.
It totally changed the look
Did you have to remove the door cards to change the door handles or is there enough slack in the cable to pop them out?
- Sean1066
I had to remove the door cards to get to the screws that hold the handles in.the swan fiend wrote: ↑Thu Dec 13, 2018 5:02 pm Did you have to remove the door cards to change the door handles or is there enough slack in the cable to pop them out?
There probably is enough slack but I didn't want to risk braking the cables.
Ahh ok cheers. It’s a job I’m thinking about doing myself
