2012 odometer whilst driving?
Trials 21
Post by Trials 21 »
Hi there is there a way I can display my total odometer whilst driving(like the picture shows) instead of it changing to display kph in its place? Image
Sent from my Pixel XL using Tapatalk
Trials 21
Re: 2012 odometer whilst driving?
Post by Trials 21 »
Bump
Liam
Post by Liam »
if you turn off cruise control it will revert to odometer i think - thats assuming u have cruise control as thats how my 2016 works
Build thread here
Billyblunt
Post by Billyblunt »
No, it flips over to Kph as it's apparently a requirement to pass an mot as your clocks only show Mph.
Liam
Post by Liam »
our irish ones show kph i assumed thats what he regerred to
Build thread here
Billyblunt
The UK main clocks show Mph but the little display flips to Kph when you drive off. It's annoying as I'd rather it stayed on the total mileage but apparently it's a requirement.
Liam
Post by Liam »
must check it out tomorrow when it gets back from the paint shop
Build thread here
Billyblunt
Yes it would be interesting to know if a Kph flips to Mph?
Liam
Post by Liam »
so this is what i get while cruise control is on but not active i have no current total mileage
however when i turn off cruise control my odometer returns
Build thread here
The original poster has a midline instrument cluster, on this cluster the bottom line shows the trip distance, the next line from the bottom shows odometer when stationary and kmh when moving.
I don't think there is any way around it on the midline instrument cluster.
Liam
Post by Liam »
ahhh makes sense doc well spotted
Build thread here
Geraout
Post by Geraout »
Can the country be changed to Australia with VCDS as the highline can?
This adds the option of turning off "Alt Speed Display"..
Where do you get this option on the midline instrument cluster? There is no "settings" screen.
Sean1066
Post by Sean1066 »
Doc wrote: Mon Dec 03, 2018 11:38 pm The original poster has a midline instrument cluster, on this cluster the bottom line shows the trip distance, the next line from the bottom shows odometer when stationary and kmh when moving.
Do you have to change the midline instrument cluster to get the same cluster as Liam or can you change with VCDS?
Caddy maxi 3.2 VR6 EX BG
My build thread
Billyblunt
Now that's a question close to my heart as I think I have the midline & It's very basic. If you could change some of the screen options via VCDS, that would be ace.
