My BG Caddy maxi build
Liam
Re: My BG Caddy maxi build
Post by Liam » Mon Dec 03, 2018 10:55 pm
its gonna totally transform the look of it
Build thread here
Sean1066
Post by Sean1066 » Wed Dec 05, 2018 6:01 pm
Got my caddy lowered today. With a vmaxx coilover lowering kit.
I’m thinking the back could go a bit lower! But I will give it a couple of weeks and see what the ride like.
It’s starting to look good
Ex BG 2011 Caddy maxi CR20 TDI,
Remapped to 140, Colour coded bumpers, VW Cadiz 18s Vanstyle roof rails, Vanstyle bumper protect.
viewtopic.php?f=13&t=36851
Liam
Post by Liam » Wed Dec 05, 2018 6:19 pm
back needs to drop at least 1 hole did u cut the bump stops ?
Build thread here
Sean1066
Post by Sean1066 » Wed Dec 05, 2018 7:00 pm
It's got one more hole to drop.
I think it needs that it needs to go to that hole and get the bump stops cut
Liam
Post by Liam » Thu Dec 06, 2018 8:22 pm
looks real good tho
Build thread here
Sean1066
Post by Sean1066 » Thu Dec 06, 2018 9:34 pm
looks real good tho
Thanks Liam
I'm trying to get it away from the BG look 😉
But I think the colour is a dead giveaway 😂
Liam
Post by Liam » Thu Dec 06, 2018 9:36 pm
GrittyBass not britishGas
Build thread here
Post by the swan fiend » Fri Dec 07, 2018 6:40 am
Nice looking van mate, I’ve got an Ex BG maxi too. Saw one near ours a while back, that had been colour coded, with a colour coded roof box on. My jaw hit the floor!
Sean1066
Post by Sean1066 » Fri Dec 07, 2018 8:27 am
There are a lot of Ex BG van where I live. some have had bumpers colour coded.
But I have never seen one with a colour coded roof box.
Post by the swan fiend » Fri Dec 07, 2018 3:01 pm
It was the first and only one I’ve ever seen. Looked the biz!
Sean1066
Post by Sean1066 » Thu Dec 13, 2018 4:30 pm
So just an update on what I've been doing
Window switches arrived the other week with then new door handles.
So I got round to fitting them today.Image
Sean1066
Post by Sean1066 » Thu Dec 13, 2018 4:41 pm
But the best thing I got done was fitting the Audi TT air vents.
(Well I think it the best thing I've done todayImage)
I started with this and had to adapt it so the TT air vents fit
Had to do a lot of cutting to get to look like thisImage
When I finished all 4 I put them in.
And what a difference it makes.
It totally changed the lookImage
Post by the swan fiend » Thu Dec 13, 2018 5:02 pm
Did you have to remove the door cards to change the door handles or is there enough slack in the cable to pop them out?
Sean1066
Post by Sean1066 » Thu Dec 13, 2018 5:15 pm
I had to remove the door cards to get to the screws that hold the handles in.
There probably is enough slack but I didn't want to risk braking the cables.
Post by the swan fiend » Thu Dec 13, 2018 5:16 pm
Ahh ok cheers. It’s a job I’m thinking about doing myself
