My EX BG VR6 3.2 build
Liam
Re: My BG Caddy maxi build
Post by Liam »
its gonna totally transform the look of it
Build thread here
Sean1066
Post by Sean1066 »
Got my caddy lowered today. With a vmaxx coilover lowering kit.
I’m thinking the back could go a bit lower! But I will give it a couple of weeks and see what the ride like.
It’s starting to look good
Caddy maxi 3.2 VR6 EX BG
My build thread
Liam
Post by Liam »
back needs to drop at least 1 hole did u cut the bump stops ?
Build thread here
Sean1066
Post by Sean1066 »
Liam wrote: Wed Dec 05, 2018 6:19 pm back needs to drop at least 1 hole did u cut the bump stops ?
It's got one more hole to drop.
I think it needs that it needs to go to that hole and get the bump stops cut
My build thread
Liam
Post by Liam »
looks real good tho
Build thread here
Sean1066
Post by Sean1066 »
Liam wrote: Thu Dec 06, 2018 8:22 pm looks real good tho
Thanks Liam
I'm trying to get it away from the BG look 😉
But I think the colour is a dead giveaway 😂
My build thread
Liam
Post by Liam »
GrittyBass not britishGas
Build thread here
Nice looking van mate, I’ve got an Ex BG maxi too. Saw one near ours a while back, that had been colour coded, with a colour coded roof box on. My jaw hit the floor!
Sean1066
Post by Sean1066 »
the swan fiend wrote: Fri Dec 07, 2018 6:40 am Nice looking van mate, I’ve got an Ex BG maxi too. Saw one near ours a while back, that had been colour coded, with a colour coded roof box on. My jaw hit the floor!
There are a lot of Ex BG van where I live. some have had bumpers colour coded.
But I have never seen one with a colour coded roof box.
My build thread
It was the first and only one I’ve ever seen. Looked the biz!
Sean1066
Post by Sean1066 »
So just an update on what I've been doing
Window switches arrived the other week with then new door handles.
So I got round to fitting them today.Image
My build thread
Sean1066
Post by Sean1066 »
But the best thing I got done was fitting the Audi TT air vents.
(Well I think it the best thing I've done todayImage)
I started with this and had to adapt it so the TT air vents fit
Had to do a lot of cutting to get to look like thisImage
When I finished all 4 I put them in.
And what a difference it makes.
It totally changed the lookImage
My build thread
Did you have to remove the door cards to change the door handles or is there enough slack in the cable to pop them out?
Sean1066
Post by Sean1066 »
the swan fiend wrote: Thu Dec 13, 2018 5:02 pm Did you have to remove the door cards to change the door handles or is there enough slack in the cable to pop them out?
I had to remove the door cards to get to the screws that hold the handles in.
There probably is enough slack but I didn't want to risk braking the cables.
My build thread
Ahh ok cheers. It’s a job I’m thinking about doing myself
